Got back to this after a couple months. There is no wet signal coming through. All ICs have voltage. Part of my problem is not knowing exactly how this circuit works. I traced an audio signal to the cathode of D3 then no signal into R12 which feeds directly to the input of the MN3007. I've reflowed solder and was going to re-verify the parts again. The Level pot works as intended but no others.On the MIx pot I have signals on lugs 1 and 2, nothing on 3. On the trimmer there is signal on lug 2.
I've switched out both the MN3007 and the CD4047 with no change.
Any hints on where to look will be much appreciated.
