bye felicia
These are awesome! How do you do them?The Return to Glitter TowneView attachment 109137
I’m documenting the process so if anyone is interested, I’ll make a thread about it!These are awesome! How do you do them?
MOAR SPARKLEZ!I’m documenting the process so if anyone is interested, I’ll make a thread about it!
Technically all off the bench, but I haven't shown off any sweet white ink on matte black sand in a while, and I don't feel like making a bunch of build reports -
In order, left-to-right, top-to-bottom:
- Cepheid w/ Speed range, Vibrato, and Delay time toggles
- Lumitron w/ lower tuned filters
- Prismatic
- Lead Solder OD
- Sunstone w/ Univibe cap values
- Pepperbox
- Polar Cap
- Lumitron
- Sea Horse w/ delay time and shape tweaks
- Awful Waffle w/ comp cap, LM709, and brighter
- Nutty Fuzz w/filter cap toggle
- Proletarian
- Pacifier w/ more lowend and asymmetrical clipping on both sides. Fuzz side modded to Os Mutantes spec
- Low Tide mini
- Woodpecker
- Frajeelay modded to Turbo Rat spec w/ Asym IR / Red, Symm Red, and No diodes
- SoulDrive
- Butthead w/ LED clipping, diminished high end, and expanded gain range
Suspect that may just be a diode array.My first dislike is the mix of THD and SMD in the signal path, makes modding the output difficult. Another is the switch between True Bypass and 'Hardwired" Bypass. The 'Hardwired' Bypass is inferior in every way so it should have been True Bypass only from the get-go. The last is the output impedance, it is comically high at 10K. What I do like is the fourth transistor stage, just like my Ernie Ball Wah it buffers the signal coming out of the feedback loop. The second thing I like is the Range capacitor C6 is doubled from stock so it shifts the filter lower. Power looks like it is better Regulated but I can't find the type of component it is. If someone more familiar with SMD can help identify I would appreciate it greatly. Part Number is either IG126 or lG126.
I don't remember the exact value, but it was something high for the comp cap. Above 1nHey, I know this was like two years ago, but do you remember how that Awful Waffle worked out with the 709?
I’ve got a Waffle on the bench and I happen to have some metal can 709s. I was debating whether it would be worth also having to mess with/ figure out what to use for a comp cap.
Thanks! I’ll give both of those a try.I don't remember the exact value, but it was something high for the comp cap. Above 1n
The OP07 is fun in it, too. And, it doesn't require a comp cap
With a transformer!
It's got an antibuffer in it : PWith a transformer!
