Preamps builds: Figment & Decadence
fibz
5.00 star(s)
Just wanted to show you guys my two builds. Luckily I read about the volume hint for the Decadence preamp.
While I was very satisfied with the Figment's decal it seems I wasn't paying attention while drilling the holes for the Decadence. :-/ the mid control and the LED hole got seriously off center :D
Otherwise I tried to adjust the Figments JFET but eventually let my ears be the judge. And the waterclear LED for Decadence turned out to be way too bright, even with the fresnel lens :ROFLMAO: next time I try a higher value for the CLR
Both fun builds!
Great work! I have always loathed that Peavey logo - apparently Hartley Peavy designed it when he was at high school, and it shows! So you were brave to work with it but I think you did well.
I can't quite make out what it says on the Figment at the bottom, between the Figment and the switch... It probably doesn't matter!
Thanks! I copied that out of the Sovtek Mig-60 faceplate. Afaik it's just saying "Sibir" which translates into Siberia. And I know a Mig-60 is not the Mig-50, but I had a beige enclosure in my stash and saw this Sovtek model and thought "why not?" :)
Looks great! I like the Figment quite a bit, have the decadence in the cue. For the decadence, I have been looking for peavy style knobs without much luck, Ireally like how you incorporated the coloring behind them, may steal borrow that idea!
Haha. Please do steal. That’s why I posted the pedals :-) but don’t mix up Post and Pre like I did. ;-)
I also looked for Peavey style knobs but didn’t have any luck too. So to get the coloring I did those „rings“.
You might find Peavey style knobs at Antique Electronics: tubesandmore.com
You got me thinking with your "Sibir" logo. May you should work out how to spell KLON in Cyrillic and build a Kon because you already have the Siberia bit. Why he calls it Klon Siberia I don't know. Maybe Finegan is a Siberian/Irish name?
