Futzing with FETs
drew.spriggs
Howdy,
I've been on that FET binge while looking at amp/preamp emulation, and came across the original Foolin' With FETS article which includes a push-pull stage. With that in the back of my mind while I was looking through other schematics, I noticed pretty much just everything uses a SRPP (or incorrectly described mu-amp).
I got to thinking - is the only reason we don't see the push-pull stages more that it's harder to find p-channel FETs, or was there something else going on? PP stages are a lot less complicated, don't require potentially noisy vref (these stages always seem noisy) and no electros needed.
Fired up the obligatory LTSpice and tried to see what I could come up with using off the shelf parts using the first stage of a modified BSIABII.
Not absolutely identical, but we're definitely in the ballpark!
Anybody else tried this sort of stage?
There's something like this in the SuryBear spring reverb, which is a recreation of the Fender 6g15. The reverb driver stage uses N and P channel mosfets.
How did you choose the P-chan JFET? Been thinking of getting some in for tinkering. Had my eye on the J177 as it's used in some of those AMT designs.
So there you go. Not a massive difference, and using much less board space. The lower bandwidth of the PP stages is actually advantageous - the rolloff is similar to where the original design has a couple of staggered LPF's before the tone stack, so response is almost identical if I use staggered HPF's.
