Episode booster (from musikding)
leurne
hello all
i've made a episode booster, thinking it is easy enough for me....
but... It doesn't work :'( i get a bad and big buzz even when the pedal is not activated. When i activated i get no sound...
i've attached the picture. I had some question about the transistor... I install a 2N5457 instead of a very small supply by musikding. And the other one doesn't have the same name than on the drawing.
when i turn on the pedal it's turning ON, and i get the led light.
Seems the solderings are fine....
It’s not the capacitor I am worried about. It’s the charge pump itself. I see this one has a switch for 9v and 18v. I thought you plugged in 18v (that’s my bad). Use your Dmm to verify on pin 8 of your ic that it has 9v and 18v depending on the switch. Pin 8 is the top right. Let’s start there and make sure power is good. Then we can move on.
Ok that mean I measure between the 9volt + and the pin8 , is it right?
Put your black lead from the dmm to a ground and the red to pin 8. Make sure your dmm is set to voltage. You should get something like 9v and 18v depending on the switch.
Another thing that will be helpful is an audio probe. Do you by chance have one?
Ok I will try when I’m back from work! Thanks a lot!
Audio probe 🤨 I even didn’t know what it is until I google it 🥲
So I’ve just measured
9v supply
Switch : 9v : 8,97v
Switch on 18v I still get of course 8,97v
18v supply
Switch on 18V: 17,4v
Switch on 9v: same
So power seem fine. Next, since you are saying you get a big buzz in bypass it leads me to think something is wrong with your offboard wiring. Check and make sure your soldering on your switch is clean and no extra wire is touching anything. Even if your circuit is faulty you shouldnt get noise when it it’s bypassed. That can only be related to the switches or jacks.
Since I’ve made again my soldering, the noise is very clean now
(And thank you for all your help 🥹🥹)
i've made some test with my assistant, chatgpt:
VCC: 9v
Vref: 4,5v
Q1: we identified it was inverted.... So i've installed the one supplied by musikding and ive check the voltage to know which side to connect. Now i have, after adjusting the BIAS:
4.6/4/4v
after done it, i got some very light guitar noise out of my speaker. when i adjust the potentiometer for the booster, the noise change.
I've check Q2: 2,8/8,9v/3,2v
i've double check also if C2 and C7 was correctly install with the right uf: both are 10uF.
i've check R7: 0,9M ohm
R9: 100 ohm
R11: 46,6k ohm.
I've gone a bit further and it seems Q2 is dead.... I've made a diode test with Q2 face to me (with the reference wrote facing to me):
seems it's alright and functionnal
It’s working! I put back Q2.
Q1 was again inverted. I think first Q1 was inverted, then I remove it and install the transistor given by musikding which is not exactly same. But I install it again in the wrong way. So I swapped it and it’s working! Everything is in the box… then it didn’t work… but I found the long foot for the female jack was touching the casing … so I turn it a bit and it’s alive !
With my daughter’s design
Oh and I forget thanks @Audandash !
