3-band EQ (Acoustic guiar) Hot-wired into a stomp box?
Dumpster D
Can it be done? This might very well be THE most burnt out pedal project idea ever envisioned :p
Sheer 'who would ever attempt something this dumb'
I could actually be that guy!!
Although they say;
"If it works, is it really a dumb idea?"
This is why I have to ask first, if you have any thoughts on a project of this magnitude?
I don't know. Diving into shallow water head first.
Last year the pawn shop guy threw in one of these cheap little 9V acoustic guitar 3-band EQ's that had been collecting dust since the 90's (Pickup not included) To sweeten an exchange of old busted Junk-for old busted Junk.
My vision was to mod it into a simple enclosure to plug into some Lo-fi Cigar box amps that don't have onboard EQ's or tone controls (Vintage portable transistor Radios I've modded into guitar amps) maybe it's just isn't supposed to work that way, which is why I don't see anyone else doing it, so far I can't find any good examples to follow.
It doesn't even need to have a bypass switch, honestly plug and play works for what I'm hacking around using it for. It's mainly for LO-FI applications here.
The idea came to me, trying to research Frank Zappa guitar Modifications. (Sorry for name dropping Zappa, a true genius has no business being mentioned here in such a weak, feeble-brained post)
Zappa apparently had some type of onboard 3-band EQ installed into one of his guitars at some point with a green ringer. I'm not quite sure of the specific function or intention of this mod, other than being on a big stage and too far away from the amplifier to adjust tone controls.
Presumably he was using something a bit like one of these cheap little acoustic guitar EQ things?
Is this even practical? Has this been done before? If so, I am very interested to learn more.
I would call the necessary engineering involved a 'Commando mod' by definition. The challenge of finding an unconventional solution to a problem. Before getting started, I should ask if it's possible/practical to be done? Is it just a pile of worthless pawn shop junk in a box? Seems like it might be almost too easy, but never underestimate any small project. The inspiration was just doing something fun and see if it works.
Ok go easy on me guys!! I'm new here. Maybe there's just a DIY 3-band EQ stomp project out there you could show me, or maybe there's already a pretty good pedal out there that's exactly this.
Alright cool.
Edit* Apologies for those of you who clicked on this expecting to see photos of something already finished. Forgiveness please!
"Maybe there's just a DIY 3-band EQ stomp project out there you could show me, or maybe there's already a pretty good pedal out there that's exactly this."
Yep, here's a recent addition: https://www.pedalpcb.com/product/pcb140/
Nothing wrong with your idea though, but without pics and other details it's tough to know how much work you'd be in for. I've ported what was originally an onboard bass preamp design into a full blown EQ pedal, but it's neither cheap, lo-fi, or a particularly easy build. ;)
Oh, and welcome to the forum!
Thank you, I'll have to dig this EQ out from its hiding place in the stash and get some photos soon, the pawn shop guy had the original box for it.
Indeed, I had a feeling I might be in for some trouble with this type of project. The 'acoustic preamp' PCB might be just what the doctor ordered.
The majority of the work looks like it will be fragile and persnickity, they deliberately made these boards split level with those little wiring sockets/pins you'd see plugged into a motherboard. Fragile and hard to Macgyver.
Also, thank you for welcoming me here.
I recently breadboarded the Ginsly preamp that @Passinwind referred to and it works very well. Plenty of gain and effective tone controls.
Just as a FYI, this is the Github repository for my open source DIY EQ pedal project: https://github.com/Passinwind/PW3B-LPF
But I’d start with the Ginsly board, it’ll be much much easier and probably all you need for your use case.
Thank you very much!! That's more gain than I know what to do with haha!!
Then again, there's no such thing as too much gain?
For me it would be like putting ketchup on my ketchup.
That being said, more is more.
Might come in handy to substitute the Gain on that EQ pedal, instead of running a buffer pedal with the Cigar box amps,
It'll be cool to experiment in tones.
The 3-band EQ seemed to be useful for a cigar box amp, it's just cheap and lo-fi, you know?
Currently in my pedal chain, the boost pedal goes after the (Dunlop) Crybaby because of bypassing the buffer stage of the wah pedal when I upgraded it to have True bypass.
Without the buffer stage in the wah pedal it sounds pretty lifeless unless there's a boost plugged in on the end now.
On that note, it seems that most people like to run their Fuzz pedal *After* the wah in a chain?
I place a Fuzz (Shin-ei companion) before the wah and prefer that... I dunno, It just sounds more nasty.
You know the classic Shin-Ei Fuzz/wah pedal itself is such a gnarly tone.
This is the closest I could approximate an original shin-ei Fuzz/wah for now, call it the poor mans solution.
I have a bunch of different amp setups for different applications of course.
In this case I've Hot rodded a single coil pickup with a 330K volume pot to drive a Green ringer into a Fuzz/wah with a JFET boost on the end... The hotter pot gives a little extra push over the cliff. Not to mention almost fully dimed amps. (The small portable amps are lo-fi but you can just let them scream without blowing your neighbours away) Otherwise the Green ringer doesn't really seem to come to life and really really start to scream!!
