This Week on the Breadboard: EHX Germanium OD
Chuck D. Bones
Circuit Wizard
I was combing thru my schematic collection and ran across this circuit. A quick listen to an Andy Martin demo and it was time to breadboard! The EHX version is built around an NTK275 PNP Germanium transistor. Apparently, EHX wanted to keep the number of different part values to a minimum. The ferrite beads and 100pF caps are there to reduce RF interference. EHX puts them in many of their pedals.
I have some AC127s (NPN Ge) that I wanted to audition, so I flipped the polarities and ended up with this. Q1 is the amplifier stage. Not all that different from a RangeMaster. Q2 acts like a variable power source. With the VOLTS control, you can dial from 3V to almost 9V for powering Q1. Q3 is a buffer to keep whatever comes next in the pedal chain from loading Q1. The BIAS control varies Q1's collector current from around 40μA to almost 300μA. The GAIN control varies the gain from just above unity to about 35dB at 1KHz with all knobs dimed. All of the knobs interact and there are a whole lotta tones in there from clean to treble boost to light OD to gated fuzz. At low gain, the freq response is flat. At high gain the bass and mids are rolled-off and we have a treble booster. Reduce C1 to cut the bass at lower GAIN settings. Increase C5 if you want more bass at higher GAIN settings. Or install switches. The BIAS pot makes it possible to use just about any Ge transistor in this circuit. The AC127 I have in there is quite leaky (Icbo = 450μA) and it works great.
To me, it seems pretty weird to build a dirt pedal with no volume control, but it works ok here.
Knobs, L-R: VOLTS - BIAS - GAIN.
Q1 in the center. Q2 is just below the VOLTS pot. Q3 is lurking beneath Q1. On the far left are an MP38A and a 2N1308 on deck.
Just curious why Q2 is necessary? What would happen if it was omitted, and the "volts" pot was wired in series with Q1's collector?
Also, this circuit would likely be impacted by temperature, right? Given that it's "heart" (Q1) is GE? Presumably some tweaking of bias/gain/volts is needed in different environments?
Good questions.
Q2 provides a low-impedance source. That means Q1's collector load is always 15K (R6). If we take out Q2 and wire R6 to pin 2 of the VOLTS pot, then the collector load is variable and will get as high as 55K. Will it work? Yes. Will it work as well as having Q2 in there? No.
The resistance between Q1's emitter & ground provides negative feedback which stabilizes the bias.
The minimum emitter resistance is 10K (the GAIN pot), which is high enough to keep the bias pretty stable.
A couple of other ways to look at it:
The DC resistance of the base bias network (R3-R5) is 41K from Q1's point of view. This is fairly low and will absorb a fair amount of leakage current which also stabilizes Q1's bias. It is also low enough that the circuit will not be too sensitive to HFE variation.
The voltage at the emitter is around 3V, depending on the BIAS setting. This is huge compared to Q1's Vbe, which means that the circuit is not sensitive to Vbe variations.
Bottom line: if there is enough resistance in the emitter circuit, then the bias point will be very stable. This circuit has plenty of emitter resistance, even with BIAS dimed.
IMHO, EHX did a very good job designing this circuit. It will do all of the stuff we want it to do and none of the stuff we don't want it to do.
Would it be a fair comparison to the two stages of a dual-triode (vacuum tube/valve) (low-gain/low imp, hi-gain/hi-imp)?
If Q2 were taken out, and you added a Q1S-Q2E resistance, rearrang...and held it up to the light just right..on second thought, it'd still be nothing like a 12AX7 preamp circuit.
Like triodes, Ge transistors have a fairly low output impedance. High μ triodes, like the 12AX7A, have a low transconductance, but they more than make up for it with a higher output impedance (plate resistance). Low μ triodes, like 6AS7, have a high transconductance but an extremely low plate resistance.
Sorry for being a bit late to the show...
I was wondering about the C5 increase: I tested with 1500nF in parallel with C5, making it about 2uF in total, and I also added 2.2uF in parallel to get to 4uF+, and I felt both setting were good, some bass increase and a bit more again.
Is there a way to do this with a single switch? To have one cap by default, 2 caps in another setting and 3 in a third setting?
I think I figured it out, so posting a sketchy drawing for closure/the archeologists.
Ya beat me to it! It will pop when switching. To cure that put a 1M resistor from pin 1 to 2 on the toggle switch and another from pin 2 to 3. I recommend film or tantalum caps.
Thanks, but I wanted C5, C5 + Ca, C5 + Ca + Cb. As the options.
So one default, then two, then all three. Maybe I wasn't that clear about that. Sorry.
By choosing the correct caps, you get the same effect. Whether you parallel 2 caps or 3 to get 4+uF, it doesn't matter. The electrons don't care.
I'll spell it out for you:
C5 = 470nF
Ca = 1.5uF
Cb = 3.3uF
C5 + Ca = 1.97uF
C5 + Cb = 3.77uF that should be plenty close. If it's not, then use 3.9uF (not as common) for Cb.
C5 = 470nF
Ca = 1.5uF
Cb = 3.3uF
C5 + Ca = 1.97uF
Thanks! I just happened to have 470n, 1.5u and 2.2u in my drawer.
Outnof curiosity though, would my initial idea work as well?
And a 1M would be enough for pop reduction say between 1 and 2 pins on dpdt?
I understand that other caps and spdt is preferred, but I just wanted to learn if my idea would work.
I think it will but you should try it and see for yourself.
The point of the anti-pop resistor(s) is to ensure that all of the caps are charged to the same DC voltage before they are switched into the circuit.
That means that Ca & Cb each need a resistor.
It's also important to remember the value tolerance. Just because the values on the package sum to 3.9uF doesn't mean that's the actual value. It could be 3.5uF or 4.2uF.
Sure, thanks. I just noticed:
Stock, 4xstock, 9xstock were noticeable for bass effect. Probably enough for tolerance differences to not play any major part.
