PedalPCB Angry Andy Plus/JHS AT+
OD is Glorious
3.00 star(s)
I am a sucker for switches and overdrive. In my opinion the boost on this pedal is somewhat underwhelming. With that said there are a few things I will test tomorrow. I did not have the LM833 op amp (it will be here tomorrow), so I used an NE5532. Also the build docs call for a BC549C transistor but I used a BC549b (C will arrive tomorrow). I imagine that transistor is in the boost circuit and it may be why that boost in underwhelming. The boost also adds a slight tone change which I am not a fan of. The drive is just like many other pedals... fuzz, overdrive and sustained full on distortion - and other pedals do each better. I went with a tango green enclosure from Stompbox and green tall thin anodized knobs. The switch is a short bat Taiway and the LED bezels are sleek 5mm from Tayda.
It was a challenge trying to make this with one thumb, and I did have two unforced errors - brain related. First time on the PedalPCB platform I had no boost so I checked the resistors in the boost circuit and found I had a 510r where I should have had a 510k, After I replaced that resistor the circuit worked straight away on the PedalPCB platform. But the boost was just above unity and with a tone coloring. The next error was on my decal label... so I already fixed that but it will need to dry a day before a reboxing. Probably also an error ro use such long wires but oddly enough, soldering is the hardest part of assembly with one thumb. The two footswitches were a challenge to solder.
IMO the pedal would not end up on my board. Not my style, It is aggressive and it does not produce exactly wbat I enjoy. Again. maybe tomorrow with the correct Op amp and transistor it may surprise me and I will update this. Anyone here a fan of this circuit?
this transistor is only serving as a mere input buffer (emitter follower) so i have doubts that BC549B v. BC549C would make any difference in this scenario.
since this is basically a modified guv'nor, i would expect this pedal to kick arse. especially with the boost which is essentially a TS808 with fixed gain & tone controls. (ive got a board waiting to be built)
Looks like my parts are not going to arrive today to do further testing. I’ll get back to you tomorrow on that transistor. And whether it produces any change.
Note: still waiting on parts but I plugged it in to my Super Reverb and it sounds a lot better. Maybe I was too harsh in my original assessment.
Well, I think my build is a pretty solid pedal, and I would guess captain squealies AKA @owlexifry would like it.
It's kind of like a marshall-in-a-box, but it maybe doesn't have the obvious gain range as, say, the Skreddy Major OD or the Colombo Plexi Breed. It really skews pretty quickly towards turbo high gain and excels at chonky chugs all day long, especially with boost. In the same kind of ballpark as modernish drop-tune-'n-tite-chug metal pedals like the BE-OD and the Revv3. Which is odd, because I don't really know Andy Timmons, but looking him up, he doesn't seem like the most metal. Maybe metallic jazz-inspired lead noodling? Not my thing.
The other flavor of modern high-gain metal pedals is looser, kinda Dual Rec? sounding, like the Revv 4, the Soldano SLO. I don't know if that's more your jam.
I do like the independent boost feature (meaning it will boost the clean signal as well as the effected signal).
I swapped in the correct op amp and the 549C and I notice minor discernible differences. Boost similar volume. The toggle however seemed to tamp down the signal at the 25w with the other op amp and transistor. Now the sound seems a bit more even when switching between 25/50/100. It is already ear bleeding volume on the drive pedal without stepping on the boost, so that may be why the boost circuit is not jacked up. Also, your milage may vary; I may be irrationally exuberant.
