Wizardofwoz66
Hey guys, kind of a weird one. Someone asked me to build them a Tonebender MKII/Morning Glory (Glory Hole) with a parallel blend. I had considered (not enough clearly) that there might be issues since the Tonebender uses the charge pump trick to get -9V/positive ground. Using the JMK Paralyzer for the blend, the Morning glory side works fine but the Tonebender side is dead (I've tested them without the Paralyzer and it works fine). Any thoughts on how to deal with this? Is there a way to even do it? Thanks!
Derek
Derek
