Wah inductor help
Vild
Just bought this wah to gut for a tearjerker build.
Has a hot potz 2 100k so perfect value for the tearjerker.
Also has an inductor that is shaped like the dunlop EVH one but just has the dunlop logo on it. I can't seem to find information on it and can't measure it. Anyone know what these are supposed to be measuring?
Also in the stock board it is oriented as pictured. But the tearjerker board has different pads connected. Anyone know whether I'm supposed to turn it to the left or right compared to a normal crybaby for the tearjerker board?
Also has an inductor that is shaped like the dunlop each one but just had the dunlop logo on it. I can't seem to find information on it and can't measure it. Anyone know what these are supposed to be measuring?
The typical wah inductor should measure around 500mH. I've seen wahs with inductor Henry rages from 330mH to 650mH.
Because the inductor has only two, non-polarized leads, it shouldn't matter. Just be sure one lead goes on the left side and the other to the right side.
I got that I just can't find info on this one. I just remembered that google lens exists though and was able to find a link for a similiar part. Not an exact match because the bottom is different but close enough that it might just be a production variation for the same spec. https://guitarpedalparts.com/products/dunlop-crybaby-wah-inductor-500mh
The top right and bottom left seem connected. Since they pick up on a continuity test I'm guessing those are the non polarized ones and the other two or polarized but idk. Since those two will always be on different pads plus what you said, am I understanding correctly that it will work in literally any orientation on the tearjerker board then?
An inductor is not a polarized component. It's just one long, thin wire wrapped around a core with two leads. And you are correct. Based on that photo, the top right and bottom left are connected. The other two legs are NOT connected and are used merely to help keep the inductor in place.
Oh ok cool. Thanks for your help!
Above link leads to a sold out product that's listed as obsolete.
No matter.
Since you're going to the trouble of building the TearJerker, perhaps spring for a decent inductor — which doesn't have to be an expensive custom hand-built stack of gold doubloons — for example, SBPs has the utterly awesomist bang-for-the-buck ME-6 for less than 10-$macker$.
