I want to copy and modify this pedal to suit my needs, because as it is, it is not very usable. It is a pretty simple build on its own, connection routes are visible, only normal sized components, the compressor is noise and distortion free, so would be a good starting point. But the only problem is: the opto coupler in it seems to be a custom made one. It is not one that is usually available with plastic housing, but a sealing tube is pulled onto it and the whole thing is tubular shaped, so I guess it is an LDR/LED glued together.
How could I figure out the values of the optocoupler components to copy that as well for the circuit? If it is not possible to get the values for it, if I re-create the schematic can that give a clue for which opto coupler could be a substitute?
Here is the photo:
Here is the photo:
