Dan0h
Has anyone used a TY-142P in place of a TY-141P for the Duocast build? The 141P is out of stock everywhere, but the 142p is in stock. Difference in the secondary impedance, DRC, and looks like the "2" has a different Turns Ratio: Also, if anyone can explain what those differences would potentially do to the sound quality if anything?
Very much appreciated.
141:
1. Primary Impedance: 10000 CT 2. Secondary Impedance: 10000 CT 3. Output: 100mW 4. Primary DC Unbalance: 4 mA 5. Frequency Response: + 2dB from 200 to 15,000 Hz 6. Impedance Matching: 10% over full frequency range 7. Longitudinal Balance > 45dB 8. Insertion Loss @ 1K Hz: < 1.5dB 9. Return Loss: > 26dB 10. Total Harmonic Distortion < 0.5% between 275Hz and3.5KHz 11. DCR: Primary (1-3) 820Ω Nominal Secondary (4-6) 1070Ω Nominal 12. Turns Ratio: 1 : 1 13. Dielectric Strength 1500V Pri to Sec to Core
142:
1. Primary Impedance: 10000 CT + 15% with 600Ω load 2. Secondary Impedance: 2000 CT 3. Output: 100mW 4. Primary DC Unbalance: 4 Ma 5. Frequency Response: + 2db from 200 to 15,000 Hz 6. Impedance Matching: 10% over full frequency range 7. Longitudinal Balance > 45db 8. Insertion Loss @ 1K Hz: < 1.5db 9. Return Loss: > 26db 10. Total Harmonic Distortion < 0.5% between 275Hz and3.5KHz 11. DCR: Primary (1-3) 750Ω Nominal Secondary (4-6) 217Ω Nominal 12. Turns Ratio: 2.24 : 1 13. Dielectric Strength 1500V Pri to Sec to Core
141:
142:
