MattG's Egregiously Expensive Crunch
leadfoot
5.00 star(s)
Way back when @MattG posted his original build of this, I asked for a PCB of it which he graciously sent to me. After getting all the parts, it went together very quickly which is awesome but I dilly dallied on the faceplate and getting an enclosure for it... thanks to life and work getting in the way.
Well, I got the enclosure and the knobs but no faceplate yet but I do want to post the build report because it is a really cool pedal and a breeze to build.
I went with a gold enclosure and gold knobs to go with the theme of Egregiously Expensive. When I finally get around to doing the faceplates, I'll go with black and gold.. to continue the theme obviously.
Looks great! Thanks for posting the build report!
Of course! This was a really great layout and I love the bypass switching using really common ICs. I've been digging into using the 40106BE to handle two bypass switches since it doesn't use all the pins for a single one.
I did this with two relays for a dual drive pedal (Paragon build I did for a friend).
I haven’t yet made a dual electrical bypass. I think I drew up the schematic though. It’s conceptually easy/straightforward, but the PCB routing isn’t pretty.
@MattG Is this an original or modified circuit?
The actual effect circuit is the Cornish CC-1. I copied Aion’s Cepheus schematic.
I did make a change, but I don’t think you can call it a mod. The original circuit uses a bootstrapped BJT as a buffer (I.e. the “Cornish buffer”), and a single opamp for the final (Baxandall) stage. That seemed inefficient to me, so I used a dual opamp so the input buffer was changed to use that. The goal was PCB & parts efficiency, not to change the sound. Other than that, I just added the electrical bypass switching.
I think this in the only Cornish drive pedal that I haven’t tried. Have you tried the SS-3 or compressor?
SS-3 no. The compressor, almost: several years ago, I built Aion's Oceanid, which is a Cornish OC-1 Optical Compressor Clone, but it's been sitting in my "to debug" pile ever since. It's either super subtle or I made a similarly subtle mistake.
You’re sounding like me now lol. Give the SS-3 a go if you get a chance. Very amp like but can get almost fuzzy. Not your typical TS style for sure.
It's super subtle. But you should be hearing some coloring of the tone and light compression.
