greypilgrim76
Hi All,
So I'm in the planning stages for my first 2-in-1 pedal, which will combine a Notakliché with a Cobalt Drive. I'm currently working on the Tayda drill template for putting them in a 1590XX enclosure. I took the template for each pedal and then basically did the math regarding distance between drill holes and edges of the enclosure. It was tricky, though, because the 1590XX and 125B have different X-Y axes for hole coordinates, and then each side of the 1590XX measures from different axis points. Anyway, I think I've got a roughed out template, but if anyone with more experience would want to take a look and see if I'm missing any obvious problems, I'd appreciate it.
A couple of notes: first, I moved the LED holes for each pedal to the bottom for symmetry. (Holes #10 and #11.) I know that'll put the Notakliché LED under the board, but I think there'll be room. Second, Hole #12 is for the direction switch.
Okay, here are the templates I used for my calculations:
And here's my current template for the combo pedal:
Any thoughts or warnings appreciated!
PS--I wasn't sure whether this best fit in "General Questions" or "Troubleshooting." If I chose poorly, please feel free to move it.
