The full Boss CE-1 (Karaoke Chorus and Celsius Preamp
mkstewartesq
I am a big fan of the Boss CE-1 sound but I wasn’t aware there was a clone of it until I saw @MichaelW’s build report on the Lectric-FX Karaoke Chorus. While that PCB is not a 100% direct clone of the CE-1, it captures its spirit but does not replicate the preamp section that so many players seem to love using all by itself. Luckily, our own PedalPCB makes the Celsius, which is a clone of that preamp, and MichaelW happened to have one around that he had already built, so he demoed the two pedals together. This inspired me to build them both as a two in one to hopefully get the “full CE-1 effect”.
Karaoke Chorus - The chorus effect is beautiful – lush with just a bit more of something extra (almost like a slight reverb or a flange) that isn’t found in its successor, the CE-2. I’m not a fan of fast rate choruses but I know some have complained that they wish the rate on the Karaoke could go faster – in any event it’s fine for me. On the other hand, I do wish the vibrato could go more slowly-at its lowest rate, it’s still fairly fast and so isn’t that suited to slow atmospheric playing. I see over on the Lectric-FX forum on the MadBean site that you can change some resistors to slow the vibrato down but that apparently simultaneously changes the rate sweep on the chorus, so it requires some balancing until you can find a suitable rate sweep for each that you can live with. I decided not to bother with that.
Additional comments on the vibrato - it is much more quiet than the chorus effect. The third setting (“wet“) is basically just the wet vibrato signal without the original guitar signal mixed in. Some may like it but I’m not a huge fan of pitch-bendy sounds, which is basically what you get when you take the original guitar signal out.
Celsius Preamp - eh…. not what I was expecting. Given others’ reports of a lot of additional headroom and gain, I don’t know if I just had different expectations or if perhaps I did something wrong in the build. Low mode on mine is just a clean boost that doesn’t even hit unity until fairly far along in the dial. Once it goes above unity it might add the slightest amount of body, but I could also be imagining things just because it’s louder. High mode surprisingly removes a lot of high-end and thickens up the sound and once you get toward the upper end of the dial, starts distorting but, to me, not in a particularly pleasant or useful way. So I’ll probably use High mode when I want a mellow darker sound, and Low mode when I want things to be louder but not really change the tone.
(I don’t have the white noise issue that some reported, as I built Robert’s updated version that fixed that.)
Notes:
  • Some have noted that the input and output jacks appear to pick up ticking in certain modes so, both to avoid that and due to the general nature of my build, I placed the jacks as far away from the board as possible and used shielded cable to boot. Unfortunately, due to the odd placement of the input and output pads on this board, that resulted in a really long run of cables from the board to the output jack. (All that being said, when I was testing the chorus before combining it with the preamp, I used unshielded cables and did not experience any ticking or other noise. So the shielded cable may have been unnecessary but I’ve gotten in the habit of using it so no big deal.)
  • I may need to replace the CLR for the rate LED with a higher value. I’ll have to check the schematics to see what’s in there now but not only is the LED somewhat blinding but it barely registers any change related to the rate (on a very slow rate you can see a bit of a faint pulse, on fast rates it just stays lit the whole time). That actually surprised me because I recently completed the Lectric-FX Old Chap, and the rate LED on that build is a very gentle, very pleasing fading in and out throughout the rate sweep. So again, I need to see whether this build used a different CLR for the rate LED than the Old Chap or, who knows, maybe I put the wrong value resistor in.
  • I again used a film-free decal and was very pleased with the results. Once the decal had cured in the oven, I applied clearcoat and then drilled. In the future, I will do the drilling before applying the clearcoat, as the small metal shavings from the drilling created micro-scratches in the clearcoat which I then had to buff out as best I could with rubbing compound.
Thanks for looking,
Mike
That's such a great looking build. Thanks for posting this. I didn't have any issues with the build (there's my crappy demo floating around at MB I think). I owned the original and used it for years but let it go in the 80's so hard to tell how close it is but I love this board.
Good on you for incorporating the pre. That was always a bugaboo on the original, setting up the gain level but it tended to be pretty forgiving if you didn't mind seeing a red clipping light.
I'm not at all a fan of the wobbly stuff either and on the original I never used the vibrato mode. I was more a fan of the slow chorus sound so the speed limits were never an issue, either on the original or the Lectric-FX version.
point of clarification: the karaoke comes with the preamp, it's just the values are set for guitar.
Kinda sorta? At least when someone posed that question on the Lectric-Fx board over at Madbean (specifically whether the CE 1 preamp was included and could achieve the distortion that some players like), the response from Lectric-Fx was:
“The input stage filtering is the same, but the gain reduced a bit to suit most modern pickups without clipping the BBD (which I can assure you does not sound pleasant) and the op amp is a) only run at 15V instead of 28V (although that should really only mean it requires less input to go in to clipping) and b) not the original type which may have had better distortion characteristics.
So yeah, if you run a clean boost up front that will achieve the same end and you might find it pleasing
especially if you try out a few crappier dual op amps, maybe the LM1458 or LM358 or perhaps even a rail-to-rail type capable of handling 15V supplies, I think the TLC2262 is.
I also believe PedalPCB offers a boost based on the CE-1 pre amp too which you could try sticking in front.”
Hi :)
I was wondering if you still have volume issue with your ce-1 preamp. im facing the same problem not getting enough volume out of the pedal until you turn it up all the way.
Have you solved that problem yet?
Hi :)
Actually, I don’t think that was ever really my problem (if I’m understanding your question regarding not enough volume) I think it was my ignorance of how the preamp worked as far as adding distortion in high mode. Long story short, I generally keep my preamp set to Low mode (for a clean boost without the distortion) and I find that setting it on 7 on my dial (about 2 o’clock) gets me exactly at unity volume. So that way I get just a touch more fullness and warmth without boosting the volume and potentially introducing distortion (although the distortion is much less, and requires turning the knob a lot further than it does in high mode, which gets pretty unusable for my purposes pretty quickly).
Mike
Nice build!
I’m trying to figure out something similar; I have a JC-120/160 preamp-only clone PCB and am trying to find a way to augment it with a faithful re-creation of the chorus effect. Essentially a JC in-a-box but without the power section.
Nice build!
Where'd you get the preamp PCB? I'm looking for one but effect layouts doesn't sell the paladin anymore and hasn't messaged me back.
