This Week on the Breadboard: The Spirit in the Sky Fuzz
Chuck D. Bones
Circuit Wizard
This pedal gets pretty damned close to the real tone IMHO. The power consumption is low enough that you could install it in a Tele and power it with a battery.
I breadboarded it per the Build Docs, except I used MPS6530 transistors (HFE around 70) and left out the switch. I installed 22nF for C2 & C5 because that's what I had and honestly, a 10% difference doesn't affect the tone. I quickly found out that I had no use for the BIAS knob. All the way up produced the best tone. Turning it down killed the volume and gain. I tried a few values for R1 and the smaller values sounded better to me... Mo' Nasty. I ended up with 2.2K because I wanted a little bit of resistance at the input to protect Q1 from being overstressed if it was driven hard by another pedal. I wanted some more gain, so I changed Q2 to BC549C and replaced the BIAS pot with a 3.3M resistor. That put Q2-C right around 4V with no signal. Now it goes to 11. Since the best SUSTAIN settings are at or near 10, C10K would be a better choice for the SUSTAIN pot.
This is how it looked before I deleted the BIAS pot.
I breadboarded this one before building it to trial transistors. I went with S9018s, as I had them on hand and they were near perfect hFE matches to the schematic.
We had similar impressions:
As close as any pedal I've heard. I always have to add that I think there was a speaker defect in addition to Greenbaum's built-in fuzz circuit. I've read him say it was just the circuit, but I'll die thinking there was a torn cone or cracked surround in addition unless someone can come up with a pedal that makes the sound I hear on the record. I don't think he'd intentionally mislead anybody, I just think he forgot or wasn't aware in the first place.
left out the switch
I've left it in the same position since building the pedal. I wouldn't miss it. I guess it just jumps R1 keeping it from creating a LP filter with C1? And maybe lowers input impedance?
Yep. Tried the 22nF because I didn't think I had the 20nF. Found some 20nF, couldn't hear any difference.
Yep.
I think I'll give your changes a try and see if they're enough improvement to warrant another build... though I don't think I'm going to have any BJTs that low-gain.
I find the bias knob to be the most useful part of this circuit. I found the sweet spot around 9-10am for the old shitty fuzz tone of the recording.
"Turning it down killed the volume and gain". Lol, that's why there are Volume and Gain controls available.
I stand corrected.
I put in a pair of 124 HFE transistors and I see what you mean. This circuit is not about gain, it's about that "old shitty fuzz tone." BIAS around 3 and SUSTAIN on 5 gets me there.
Yeah, there could/should be a 22K resistor in series with the BIAS pot.
So place the 22k between the collector and BIAS-1, or betwixt BIAS-3 and the gate?
Based on the discussion thus far, I imagine it should be the former (green below) not the latter (blue below):
Hm I think I thinkered it out, should be the green.
