First vero build - circuit works but output is barely audible.
zakco
My first Vero build. It’s the Mind Bender as per this layout:
The only modification is the trimpot is wired off-board to a regular pot
Voltages at all transistors are good, all controls function as expected but the output is barely audible - probably 30db quieter than it should be, but I can clearly hear that other than the output level, the volume, attack and bias pots are working. The gigantic GT404s make it difficult to see the top layout, but I've taken photos from a few angles, so hopefully everything is visible.
Any help would be appreciated, thanks!
you said voltages are all good, but post them here anyway.
be sure to check the pinout on those GT402s. - i'm pretty sure they might be BCE (as opposed to the usual CBE)
also, I just had a look - GT402 are apparently PNP.
This circuit is designed for NPN Ge transistors.
Thanks for your reply. I mis-typed - they are GT404(NPN) not 402. Sorry about that. I'll edit my post.
I breadboarded first and it sounded fantastic. The volume drop happened when I transferred the circuit to Vero. I'll post the voltages later tonight.
ah yep.
GT404 will be BCE pinout.
Correct. The pinout is a PITA, takes some creative bending to conform to the layout. I'll be shrink tubing those legs for sure.
The voltages are:
Q1: 7.4
Q2: 0.14
Q3: 7.5 (with bias control at noon)
im assuming the values above are collector voltages?
note: it's usually handy to know what the idle voltage is at each pin. e.g. Q1c, Q1b, Q1e (where c = collector, b = base, e = emitter)
I suspect ”schematic error” by solder bridge or missing/intermediate gnd connection somewhere.
Watch out for potential solder bridges between copper strips. Marked some of ’em. To exclude it being a problem run either an exacto knife couple times along area in between strips or do it with soldering station with a thin soldering tip, just be quick with going along trace gaps with tip avoiding taking solder of the copper trace itself.
Edit. JUST NOTICED SOMETHING TO EXCLUDE FIRST. You’re using sockets. Well there’s the problem most probably... Take ’em off and solder transistors back in RAW. No point in sockets IF you’re breadboarding. Then clean areas between copper traces and fire it up to enjoy your new pedal. :D
yes, collector voltages. Here's a complete measurement:
Q1c: 7.29
Q1b: 0.06
Q1e: 0
Q2c: 0.14
Q2b: 0.07
Q2e: 0
Q3c: 7.5
Q3b: 0.15
Q3e: 0
As this is my first non-pcb build, I didn't want to commit until I knew my vero work was solid. It took me a while (and expense) to find suitable NPNs for this circuit and if I biffed the vero layout in some tragic manner, I didn't want to risk destroying the transistors by desoldering! So, you believe that sockets are so inherently problematic, that they're more likely the issue than a solder bridge?
For avoiding that solder transistors with long legs until circuit operation is verified. On that kind of long transistor legs there’s plenty to trim shorter.
If you’re not using more expensive machined ones then YES and leg diameter/shape varies on transistors which causes contact looseness between transistor legs and sockets holes. Looseness tends to get worse with each transistor removal and reinstall.
My money is on both really, but q2 voltages are lean towards to solder bridge. The possible solder bridges I hilighted for you add up with it too.
Any update?
I went over every possible bridge and ruled that out to the best of my ability. De-soldered the sockets and made a big mess and got pissed off.
So...I rebuilt the entire thing from scratch on a new piece of vero and this time I skipped the sockets and soldered the transistors to the board. I went slowly and very carefully. I'm 99% certain there are no solder bridges. And...the exact same result! Voltages nearly identical, all controls working but output level is extremely low - barely audible without cranking the amp to 10.
Ugh...I must be making some mistake with the circuit itself. Pretty frustrating!
I know this is probably obvious, but did you see if someone else built this very vero and verified it? Another thing that can be done is to compare it to the parent circuit to reference what was changed to make it a Mindbender instead of a Tonebender to verify things.
appears to be
i have previously followed the mindbender schematic when breadboarding...
but that 2K fuzz / attack pot value seems kinda dumb to me, so I just went with a 1K pot.
(doubt this will change much, but might be worth trying)
try flipping that 4.7uF (input) cap too:
if i can recall correctly, there was one really strange thing i noticed when breadboarding this circuit previously - i had put the 4.7uF cap in the 'correct position' as per above, and didn't get much output, so then i flipped it to the 'wrong' orientation, and it worked fine.
- and i still don't understand why this happened.
appears to be
I tried flipping the input cap tonight but that resulted in no output at all. Thanks for the suggestion though.
The comments section at tagboard mentions the input cap being backwards apparebtly was never fixed
I saw this comment and assumed that it had been fixed. Also, I tried reversing the cap tonight and got no output at all.
