DEMO runoffgroove Splitter-Blend
owlexifry
runoffgroove describes this circuit as providing “two buffered parallel effects loops with a Blend control. Also, a phase polarity switch is included to allow phase matching of the effect loops. Possible uses are blending two sets of effects placed in the loops, a signal splitter, a simple mixer, or to blend an effect with the dry signal.”
it puzzles me that there isn’t a board (that I’ve been able to find) that can do what this circuit does.
yes there’s quite a few blending circuit pcbs, but all that i’ve seen are too small and deficient of features.
ie. phase inverter switch is mandatory, and to my great satisfaction - i found immediately on initial testing how valuable this is to have.
i built this mostly because i wanted something that would allow me to clean blend my fuzzes in front of/with the tight/modern high gain distortion that i normally use, and i've found it certainly makes for more versatility/accessibility.
this took me a long time to build and im glad i didn’t rush.
the circuit is designed with one channel having the phase inversion toggle, and the other channel is setup so that with nothing plugged into the return jack, the send can go direct to return via switching jack (for an easy clean blend).
nearly got myself into a few pickles but caught them before potential disaster eventuated.
notably, the input buffer JFET bias on the 'green channel' return.
schematic specifies 2N5457 so i went with one that i’d used for breadboarding a distortion recently.
then i read this thread describing some issues that were pointed towards incorrect JFET bias, with one poster suggesting that the Source should ideally be idling at 4.5v for maximum headroom/full response.
i checked mine just before i was moving toward the -can’t really turn back now buddy- phase of assembly, and found it was idling at 0.42V.
yikes.
so yep, it was breadboard time.
pulled out some JFETs, a 1M, x2 4K7 and setup the input buffer on the breadboard.
- all of my 5457s idled at ~0.4v 😑
- J201 - 1-3v
- J113 - ~3.0v
- PN4393 - ~3.5v
- 2N5458 - 3.0-4.8v
i was curious about how much difference all of this would make, so i set up the protoboard w/ a DAW and a clean plugin and played my P-Bass through it.
at 0.4V idle bias with 5457 - a diminished response was noticeable. glad i caught that. but not as terrible as i thought.
it was difficult to hear much difference between 3v-4.8v bias, as i tried all the JFETs listed above and then just settled on a 2N5458 that idled at 4.8v
this is definitely gonna get used and im glad i built it.
here’s a demo running two fuzzes in parallel:
- Big Muff V2
- EQD Black Ash
Damn dude. That build is impressive and you were thorough in making sure it came out the way you wanted it. NGL the "not interested" kicks in real hard when I see "clean blend" but your execution is flawless.
First, sick build. Sweet, sweet curves in those wires. I go for that look frequently, and I know it takes sustained attention to detail. Also, tidy perf (and vero) make for some really cool aesthetics. Good innards all around there.
Second, this might have saved you some time, but you would have sacrificed some style points:
GuitarPCB Paramix
cheers man 🤙🏻
This is dope! And I agree, it would be great if more PCBs for utilitarian circuits like this one were available.
thanks!
hell yeah it would - i would totally build another one with a PCB based solution.
ayyy cheers 🤘🏻 yeah it’s all about that solid core. can be risky, just gotta be gentle i guess.
yep this is vero. i don’t really do perf.
perf layouts are generally tidier, but i’m just so familiar with vero, and there’s something about the solder-side/backsides of perf that just gives me the heebee jeebees.
seems you’ve gotta be an absolute psychopath genius to not have it look like a collection of boogers on the back of a board.
GuitarPCB Paramix
ahhh nice! yeah good point.
i’m pretty sure i saw this one, but there’s something about it that i didn’t like, the schematic sorta confused me and coming from guitarpcb, seemed a bit sketchy vs. the trusted designs of runoffgroove.
also here’s a little dumb feature:
this wasn’t really planned.
all drilling was done by hand and measured out with eyeballs and steel rule.
the initial hole i drilled for the toggle wasn’t gonna suit, clashed with one of the jacks - whoops - so i had to move it down, so then had a spare hole, so i moved the bypass/on LED to that hole and the bypass/on LED hole became an ‘indicator light’ for the phase toggle position. so instead of using a SPDT, a DPDT does the job.
That’s it right there. When I do stripboard, the solder just effortlessly flows along the track and stops right where I want it. I was never happy with the backside of a perf I populated.
Also, sweet build, parallel effects are a great time.
Agreed, all the way around. If you're not familiar with HGE Contraptions, you're welcome. I want to build like he does when I grow up.
Great build, report and demo.
Maybe extra emphasis on the demo, GREAT, but then all your demos are quite good.
Seamless when you dropped the pick, grabbed another and kept riffing. Excellent demonstration of how important the phase switch is.
I've got a paramix board from GPCB, but right now I want to grab some perf (maybe vero), spray it black and build one of these for my bass fuzzes.
Light indication for the phase is good; sometimes it's hard for me to tell which way a bat-toggle is facing being somewhat optically impaired.
Hmmm maybe a second stomper for a 2-knobjob so you can switch between two blend states, but that would bump it up a size — based on your gutshot, not much room left in an N1. A 1590B3 might do it, but while wider than an N1, they're not as tall, and shorter in length to boot.
Gotta say it again great build report and demo.
haha i can tell you actually watched the demo, cheers feral, got lucky there was a spare pick sitting there.
glad to have inspired 🤘🏻
i wanna know what wire he’s using. looks really sleek, but im sure i’d make it look terrible and stripping it would drive me insane. especially if its that teflon stuff.
how good is it 👌🏻👌🏻👌🏻👌🏻
Carcharias used to have a PCB, which (I believe) was for the ROG Splitter Blend.
However, basically I think Carcharias shut down shortly after I took up the hobby, before I could snag some PCBs such as the one above and the Sagan Delay.
The Carcharias website is long-gone, but... Anyone know if that builder is still active?
(Noob here 👋 ) Was looking for simple blender PCBs too... Something akin to what Saturnworks sells in a 1590A or B. I ended up getting two of these PCBMania Blender PCBs from HMFX a while ago, but have yet to build one- a lot more going on with this, maybe more what OP was looking for, but no on-board phase switch.
HMFX Blender
HMFX Blender
This thing is very cool. I dont play with it a lot but when I do I think "i should use this a lot". Needs a phase switch though.
