Passinwind
- Build Rating
- 5.00 star(s)
I won this board in one of @fig 's contests a couple of years ago but just finally got around to building it up. It completes my current trio of ODs: hard clipper, soft clipper, opamp. As usual I did an LTspice model first so I could visualize what component swaps might do, and although I was originally going to do this one to spec I inevitably changed my mind and went a bit rogue. My intent was to reduce overall gain a little, bump bass response up a good bit, and use a more modern opamp, OPA1642 in this case. At what turns out to be a represenative setting with my particular guitar and tube amp, here are the control sweep sims for the tone control:
That would reflect a gain matched Volume setting of 7.5 out of 10 on mine and 5 out of ten on a stock unit, with Drive at 6 out of ten on both. I modeled many other settings as well to make sure my mods were likely to make me happy. Since the only Klon I've ever played through was the model in my Spark 2 amp I had to rely more on my experience building many many preamp/EQs; at this point I have a pretty clear mental picture of how a given curve is going to sound. Distortion waveforms are trickier for me though, and this and my recent Mahayana build were an attempt to get a little smarter about that. Both pedals feel like keepers to me in any case, and the build itself was very simple over just one day. I'll probably re-house with Amplifiedfun graphics soon unless I just do my own PCB with more SMD parts, which is a strong inclination.
I did have to put a few caps underneath as the only correct value ones I had on hand were polypropylene Kemets. I also lost the oddball 392k and 442k feedback resistors, going with 330k in both cases. I can detail the other mods if requested, but IMO there's nothing all that magic about them.
