Sheepylove Hebridean J201 (IDSS)?
RICHB555
I’m working on the Sheepylove Hebridean and for Q2 and Q3, the board has two spots for J201s. The J201 to the right has an indication for IDSS but not on the left. There is an arrow pointing to the left side J201. The build doc indicates measurement is required for IDSS and a higher value should be used. @Chuck D. Bones or anyone, can you advise what should be done to populate the J201s? Do I populate all four areas, and put higher value J201s where IDSS is indicated? First time I’ve run into something like this on a board. Thanks!
You got it right. If you turn over the board, you should have the resdef. That's Q3 and Q4. The build doc says that the Idss in Q4 should be greater than that of Q3. The arrow on the board is just showing you where Q3 is.
Test your MMBFJ201/J201 for Idss and make sure Q4 has higher value than Q3, and Q2 > Q1.
Thanks 👍
It's a great pedal! Impossible for me to build before Chuck's advice. To me it sounds like the ultimate Dumble sound, with a hint of Marshall. Mind you I have never played a Dumble of course!
