RICHB555
I’m working on the Sheepylove Hebridean and for Q2 and Q3, the board has two spots for J201s. The J201 to the right has an indication for IDSS but not on the left. There is an arrow pointing to the left side J201. The build doc indicates measurement is required for IDSS and a higher value should be used. @Chuck D. Bones or anyone, can you advise what should be done to populate the J201s? Do I populate all four areas, and put higher value J201s where IDSS is indicated? First time I’ve run into something like this on a board. Thanks!
