OD is Glorious
- Build Rating
- 5.00 star(s)
This is a top 5 overdrive IMO and that is why I have built different versions of this pedal - but this is my favorite. I wanted to use my favorite Davies 1510 knobs so I moved the pots closer together and used a 3mm LED. I exposed the symmetry switch and used a female pin header to get a sub-mini toggle to reach the outside. The enclosure is a 1590b and the decal is film-free with a 2k clear coat. For jacks I have begun to use enclosed mono jacks. I socketed the IN4148s and used a soft-click footswitch - the toggles are both short-bat Tawaiy. I am always happy when my decals line up the way I need them to.
Notes
Notes
- Wide board - at 2.2" × 2.25" × 0.5" the board is too wide for a 1590b. Fiberglass needs to be sanded off of each side of the PCB!
- Enclosed jacks are larger than Lumberg 1/4" TS Open Jack - KLBM 3 so I had to sand off a bit of the outer jack plastic so they could sit under the board -
- Shorter electrolytic capacitors are needed - PPCB has them - two short 47u ECs
- 820N film capacitors - not a common value - these are very tall film caps and you probably need to lay them down as I did here - from Stompbox
- 39n film capacitors - not a common value - from Stompbox
- Symmetry switch - if you want to expose this on the outside, you need a sub-mini on/on toggle with PCB pins (pins need to be filed a bit in order to fit in the pin header- For hole drilling (3/16") it goes 1.5cm below the "Range" switch and you will need a female pin header or off board wiring to get it to reach the top of the case
