What do you mean by higher octaves? Do you mean playing higher on the fret board? Curious on where your knobs are set as well. Did you make sure you used the right potentiometer too?I did check the caps. everything checked out okay. audio passes and the effect is obvious when played. it is just quiet and higher octaves are incredibly unstable. that prompted me to explore a bit further.
Yes, the higher I go on the fretboard, the more compression happens. it allows the initial transient through but then squashes the notes volume considerably. it slowly regains volume as the note sustains. the lower octave notes on the guitar seem to not trigger this compression.What do you mean by higher octaves? Do you mean playing higher on the fret board? Curious on where your knobs are set as well. Did you make sure you used the right potentiometer too?
So...I reflowed those joints (im really new to soldering and cant spot a cold solder) and now it sounds AWESOME! I checked the voltage at every point and all seems right except for Pin 3 and Pin 13 on the CD4013 and the 47n cap. Since it is working properly and sounds great, should I be concerned and sort out the cause?
Thank you so much for taking the time to help me through this. I built a reverb pedal (the Spirit Box) after I assembled this and it works perfectly.
The spirit box? Or are you talking about the mantle fuzz? I’m assuming you mean the mantle fuzz because that’s what mine sounds like too hahaIt kind of sounds like an analog synth. It has a bit of trouble tracking the note when I bend the string, but that is charming and gives it a bit of a glitchy sound. it actually sounds almost identical to the synth parts on Icky Thump by the White Stripes.
awesome! Great to hear.
how’s the spirit box? I was considering doing one soon.
My issue is of the 6 pedals I have - 3 are reverbs! Haha haven’t built one yet because of that but it’s my favorite and most used effect.The Spirit Box is a great Reverb!!! Built the circuit for my daughter and liked it so much I had to build me one!
again, I missed adding the file.
Ha! My amp has reverb too which is always on. OBSESSED.My amp has a spring reverb on it so I never thought I needed one, once I heard the spirit box I realized I really needed one!??? so of the 30 or so pedals I have right now only one is a reverb.
