Measuring IDSS for a J201 JFET on a daughterboard
Hi Folks. I've got a few Fairfield Circuitry inspired builds (Chop Shop, Nein) almost done and it's time to get into measuring the JFET's. Coming from a non-engineering background I've pored over any videos on Youtube that remotely mention measuring JFET, IDSS, or both. Many mention measuring typical looking 3 leg transistors.
It seems that if I had a loose J201 like a MMBFJ201 that I could likely pop it on the clip on board that is included on a cheap unit like the FNIRSI LCR-P1 tester. However, I ordered the J201's from stompboxparts pre-soldered to a TO-92 daughterboard. I even got the pin headers recommended by a fellow forum member. However, I realized that I can't just pop that JFET containing daughterboard on the FNIRSI LCR-P1 tester because the bottom of the JFET will not make any contact with that thing and thus won't be measurable. I do realize that D,S,G are labeled on the TO-92 daughterboard so is the answer for achieving IDSS measurement going to involve soldering the pin headers to the TO-92 daughterboard and then inserting it on the tester so it's sort of like a typical 3 leg transistor?
I soldered pin headers to mine.
Yeah that's what I was thinking. I however don't have the right angle pin headers. I have the straight pin headers. But I think that difference shouldn't matter since those pins can then just sit on a tester like the one I mentioned. Thanks for sharing.
Thanks for clarifying. I assume that it doesn’t matter which side of the pin header goes to pcb and which goes to the jfet daughter board? Mine are slightly longer on one side.
Careful all pin headers are not the same. I bought some angled male ones off Amazon to solder to my smd j201s and the pins wouldn’t fit into the female sockets I’d already soldered onto the board.
oh this is something i hadn’t considered. So are you are saying that you put pin header sockets on the pcb (male side through pcb, female side facing up towards the enclosure cover), then put the male/male pin headers through the jfet daughter board, and finally you put the daughterboard assembly onto the female socket end on the pcb? Sorry for the obvious question but in seeing the common pcb build view it is not possible for me to see if some part has stuff soldered below it.
You lost me at daughter board I must’ve missed that part. I was simply referring to inserting the smd jfet (with headers installed) into the jfet sockets on the pcb. The headers I purchased wouldn’t fit into the sockets. Supposed I could’ve went without using sockets at all but I did with the intention of swapping the jfets.
Ok your inclusion of sockets in addition to having pin headers makes sense given that you were going to swap the jfets. That's the first mention I've seen of that for jfets. I've definitely socketed for germanium transistors with those little green circle sockets. Is socketing for jfet swaps common?
It is if you don’t know all the measurements of your jfets and/or wanna use your ears to judge the differences.
Update: the FNIRSI LCR-P1 tester totally allows measurement of a jfet already attached to a daughterboard. You use the three clips which conveniently hook onto the d/s/g eyelets. I popped two 500 IDSS jfets into the desolate fuzz and it worked like a champ. IMG_8448.jpeg
I just got the tester shown above and the SMD J201s have comparable readings. I also have some questionable thru-the-hole J201s where the Idss is reading 0.16ua. Then I tested somes ourced from PedalPCB and their readings compare to the SMDs.
Is there anyway to tell what the fake ones really are?
