In search of Stereo Reverbs and Delays to fill 2 Binaura EEPROMS.
Alrighty then! I'm going to jump to R08 - 'Dual-Tank Stereo Spring Reverb' for now. R05 (Slow-Attack Auto-Volume Reverb), R06 (Diffuse Multi-Tap Tape Reverb) & R07 (Reverse-Envelope Gated Reverb) are all presenting a good bit of challenge for the time being. We might need to settle on using stereo versions of standard reverbs like room, hall, plate, spring, etc. for slots R05, R06 & R07.
So here are two candidates for R08 (Dual-Tank Stereo Spring Reverb). . . . .
This first one, in my opinion, is a bit janky for a spring reverb. It uses 3 double-tapped delay blocks to achieve the effect. And while it may be useable, I don't think it really fits the bill for a spring/tank verb effect. We can futz with the 3 different Delay blocks' Delay Time parameters (in their respective Control Panels) to get a better spring/tank effect. Still, you may find it useful.
The second one presented uses a 'Spring Reverb' designer block with both left & right inputs & outputs and only has two control pots. The 3rd pot is not used.
R08_Stereo_Tank_Reverb.spcdj
JSON:
  "formatVersion": 1,
  "buildNumber": 1070,
  "type": "patch",
  "patchFileName": "R08_Stereo_Tank_Reverb.spcdj",
  "comments": {
    "fileName": "R08_Stereo_Tank_Reverb.spcdj",
    "version": "Patch saved from SpinCAD Designer version 1070",
    "lines": [
      "Pot 0: Reverb Time",
      "Pot 1: Feedback",
      "Pot 2: Feedback Filter",
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "className": "com.holycityaudio.SpinCAD.CADBlocks.InputCADBlock",
      "blockNum": 0,
      "x": 319,
      "y": 2,
      "name": "Input"
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Pot0CADBlock",
      "blockNum": 1,
      "x": 42,
      "y": 89,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "className": "com.holycityaudio.SpinCAD.CADBlocks.ScaleOffsetControlCADBlock",
      "blockNum": 2,
      "x": 104,
      "y": 89,
      "name": "Scale/Offset",
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.36,
        "outHigh": 1.0
      "className": "com.holycityaudio.SpinCAD.CADBlocks.control_smootherCADBlock",
      "blockNum": 3,
      "x": 202,
      "y": 89,
      "name": "Smoother",
      "params": {
        "filtReg": 34,
        "filt": 0.0028321367257876373
      "className": "com.holycityaudio.SpinCAD.CADBlocks.FBOutputCADBlock",
      "blockNum": 4,
      "x": 575,
      "y": 27,
      "name": "FB Out 1",
      "params": {
        "register": 37
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Pot1CADBlock",
      "blockNum": 5,
      "x": 40,
      "y": 303,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 6,
      "x": 475,
      "y": 168,
      "name": "FB Out 2",
      "params": {
        "register": 37
      "blockNum": 7,
      "x": 216,
      "y": 199,
      "name": "FB Out 3",
      "params": {
        "register": 37
      "blockNum": 8,
      "x": 102,
      "y": 304,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.42,
        "outHigh": 1.0
      "className": "com.holycityaudio.SpinCAD.CADBlocks.TripleTapCADBlock",
      "blockNum": 9,
      "x": 403,
      "y": 210,
      "name": "ThreeTap",
      "params": {
        "inputGain": 1.0,
        "fbkGain": 0.8912509381337456,
        "delayLength": 6472.0,
        "tap1Ratio": 1.0,
        "tap2Ratio": 0.4206666666666667,
        "tap3Ratio": 0.0,
        "subdivision": 0.0,
        "delayOffset": -1.0,
        "output1": 39,
        "output2": 40,
        "output3": 0
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Pot2CADBlock",
      "blockNum": 10,
      "x": 41,
      "y": 458,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "blockNum": 11,
      "x": 324,
      "y": 282,
      "name": "ThreeTap",
      "params": {
        "inputGain": 1.0,
        "delayLength": 8091.0,
        "tap1Ratio": 1.0,
        "tap2Ratio": 0.6525,
        "tap3Ratio": 0.0,
        "subdivision": 0.0,
        "output1": 41,
        "output2": 42,
        "output3": 0
      "blockNum": 12,
      "x": 104,
      "y": 458,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.24,
        "outHigh": 0.8
      "className": "com.holycityaudio.SpinCAD.CADBlocks.LPF_RDFXCADBlock",
      "blockNum": 13,
      "x": 603,
      "y": 328,
      "name": "LPF 1P",
      "params": {
        "freq": 0.5095391792541264,
        "lpf1": 44
      "className": "com.holycityaudio.SpinCAD.CADBlocks.FBInputCADBlock",
      "blockNum": 14,
      "x": 603,
      "y": 382,
      "name": "FB In 2",
      "params": {
        "register": 37,
        "lGain": 1.0
      "blockNum": 15,
      "x": 554,
      "y": 89,
      "name": "ThreeTap",
      "params": {
        "inputGain": 1.0,
        "delayLength": 5057.0,
        "tap1Ratio": 1.0,
        "tap2Ratio": 0.189,
        "tap3Ratio": 0.0,
        "subdivision": 0.0,
        "output1": 45,
        "output2": 46,
        "output3": 0
      "blockNum": 16,
      "x": 602,
      "y": 227,
      "name": "LPF 1P",
      "params": {
        "lpf1": 47
      "blockNum": 17,
      "x": 602,
      "y": 279,
      "name": "FB In 1",
      "params": {
        "register": 37,
        "lGain": 1.0
      "blockNum": 18,
      "x": 613,
      "y": 467,
      "name": "LPF 1P",
      "params": {
        "lpf1": 48
      "blockNum": 19,
      "x": 613,
      "y": 520,
      "name": "FB In 3",
      "params": {
        "register": 37,
        "lGain": 1.0
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Mixer_3_to_1CADBlock",
      "blockNum": 20,
      "x": 341,
      "y": 421,
      "name": "Mixer 3:1",
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "gain3": 1.0,
        "output": 49
      "blockNum": 21,
      "x": 436,
      "y": 418,
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "gain3": 1.0,
        "output": 50
      "className": "com.holycityaudio.SpinCAD.CADBlocks.OutputCADBlock",
      "blockNum": 22,
      "x": 377,
      "y": 500,
      "name": "Output",
      "params": {
        "mono": true,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 0.35481338923357547
  "connections": [
      "fromBlockIndex": 1,
      "fromPin": "Control Output 1",
      "toBlockIndex": 2,
      "toPin": "Control Input 1"
      "fromBlockIndex": 2,
      "toBlockIndex": 3,
      "toPin": "Control Input"
      "fromBlockIndex": 5,
      "toBlockIndex": 8,
      "fromBlockIndex": 0,
      "fromPin": "Output 1",
      "toBlockIndex": 9,
      "toPin": "Input"
      "fromBlockIndex": 6,
      "fromPin": "Feedback Output",
      "toBlockIndex": 9,
      "toPin": "Feedback"
      "fromBlockIndex": 3,
      "fromPin": "Control Output",
      "toBlockIndex": 9,
      "toPin": "Delay Time 1"
      "fromBlockIndex": 8,
      "toBlockIndex": 9,
      "toPin": "Feedback Gain"
      "toBlockIndex": 11,
      "toPin": "Input"
      "fromBlockIndex": 7,
      "toBlockIndex": 11,
      "toPin": "Feedback"
      "toBlockIndex": 11,
      "toBlockIndex": 11,
      "fromBlockIndex": 10,
      "toBlockIndex": 12,
      "fromBlockIndex": 9,
      "fromPin": "Tap 1 Out",
      "toBlockIndex": 13,
      "toPin": "Input"
      "fromBlockIndex": 12,
      "toBlockIndex": 13,
      "toPin": "Frequency"
      "fromBlockIndex": 13,
      "fromPin": "Output",
      "toBlockIndex": 14,
      "toPin": "Feedback Input"
      "fromPin": "Output 2",
      "toBlockIndex": 15,
      "toPin": "Input"
      "fromBlockIndex": 4,
      "toBlockIndex": 15,
      "toPin": "Feedback"
      "toBlockIndex": 15,
      "toBlockIndex": 15,
      "fromBlockIndex": 15,
      "toBlockIndex": 16,
      "toPin": "Input"
      "toBlockIndex": 16,
      "fromBlockIndex": 16,
      "toBlockIndex": 17,
      "fromBlockIndex": 11,
      "toBlockIndex": 18,
      "toPin": "Input"
      "toBlockIndex": 18,
      "fromBlockIndex": 18,
      "toBlockIndex": 19,
      "toBlockIndex": 20,
      "toPin": "Input 1"
      "toBlockIndex": 20,
      "toPin": "Input 2"
      "toBlockIndex": 20,
      "toPin": "Input 3"
      "fromPin": "Tap 2 Out",
      "toBlockIndex": 21,
      "toPin": "Input 1"
      "toBlockIndex": 21,
      "toPin": "Input 2"
      "toBlockIndex": 21,
      "toPin": "Input 3"
      "fromBlockIndex": 20,
      "toBlockIndex": 22,
      "toPin": "Input 1"
      "fromBlockIndex": 21,
      "toBlockIndex": 22,
      "toPin": "Input 2"
R08_Stereo_Tank_Reverb_02.spcdj
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R08_Stereo_Tank_Reverb_02.spcdj",
  "comments": {
    "lines": [
      "Pot 1: Damping (Reverb Depth)",
      "Pot 2: not used",
      "R08_Stereo_Tank_Reverb_02"
  "potValues": [
    98.0,
    99.0,
    1.0
  "blocks": [
      "blockNum": 0,
      "x": 256,
      "y": 55,
      "name": "Input"
      "blockNum": 1,
      "x": 4,
      "y": 111,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 67,
      "y": 111,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.44,
        "outHigh": 1.0
      "blockNum": 3,
      "x": 165,
      "y": 111,
      "name": "Smoother",
      "params": {
        "filtReg": 34,
      "blockNum": 4,
      "x": 86,
      "y": 160,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 5,
      "x": 148,
      "y": 160,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.42,
        "outHigh": 1.0
      "className": "com.holycityaudio.SpinCAD.CADBlocks.SpringReverbCADBlock",
      "blockNum": 6,
      "x": 256,
      "y": 111,
      "name": "Spring_Reverb",
      "params": {
        "gain": 0.5,
        "krt": 0.95,
        "krf": 0.7,
        "klap": 0.6,
        "kap0": -0.7,
        "kap1": -0.65,
        "kap2": -0.6,
        "kap3": -0.5,
        "baselen1": 4.0,
        "baselen2": 7.0,
        "outputL": 36,
        "outputR": 37,
        "lp1": 38,
        "lp2": 39,
        "temp": 40
      "blockNum": 7,
      "x": 256,
      "y": 167,
      "name": "Output",
      "params": {
        "mono": true,
        "offset0": false,
        "gain1": 1.0,
  "connections": [
      "toBlockIndex": 2,
      "toBlockIndex": 3,
      "toBlockIndex": 5,
      "toBlockIndex": 6,
      "toPin": "Input_L"
      "toBlockIndex": 6,
      "toPin": "Input_R"
      "toBlockIndex": 6,
      "toPin": "Reverb_Time"
      "toBlockIndex": 6,
      "toPin": "Damping"
      "fromPin": "OutputL",
      "toBlockIndex": 7,
      "toPin": "Input 1"
      "fromPin": "OutputR",
      "toBlockIndex": 7,
      "toPin": "Input 2"
I agree with you. The first option does not exactly fit the description, but I do like it! I think we call that "Triple Tap Reverb" and keep it as an option.
The second spring option is much closer, but It seems to be clipping/distorting when the spring "thwip/drip" simulation noises are triggered. do you hear this as well?
Spring simulation goes beyond what the FV-1 can do convincingly, IMO. This typically uses long chains of identical or nearly so all-passes. Cranking the all-pass coefficient risks overloading the accumulator. If it's giving audible distortion, reduce the input gain. If you need more level afterwards, boost it back up. Don Stavely has a springy algo over at the Spin forum which many people have referenced. I think it includes tremolo.
Nevertheless I'd keep expectations low.
I pushed the 2nd one thru to SpinASM and loaded it into an EEPROM and hear the distortion there. We can turn the 'Reverb Time' down to about 83 from the current setting of 95. That should clean up the distortion. I'll make the adjustment and push it thru the SpinASM/EEPROM process and try it again on a Binaura build I have.
Thanks DL! I'll copy that SpinASM file and see what I can do get stereo out of it.
I’m not desperate for a spring reverb, my amp has a real tank, so I’m happy to move this one to the back burner and move on to room and hall etc.
In that case, here are four more (spread over this and the next post), R0x_Stereo_Room_Reverb.spcdj; R0x_Stereo_ROM_Reverb.spcdj; R0x_Stereo_Plate_Reverb.spcdj & R0x_Stereo_Hall_Reverb.spcdj . . . . .
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R0x_Stereo_Room_Reverb.spcdj",
  "comments": {
    "fileName": "Untitled",
    "lines": [
      "Pot 1: Pre-Delay",
      "Pot 2: HF Loss",
  "potValues": [
    99.0,
    80.0,
    96.0
  "blocks": [
      "blockNum": 0,
      "x": 118,
      "y": 15,
      "name": "Input"
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Mixer_2_to_1CADBlock",
      "blockNum": 1,
      "x": 118,
      "y": 73,
      "name": "Mixer 2:1",
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "output": 32
      "blockNum": 2,
      "x": 27,
      "y": 139,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 3,
      "x": 28,
      "y": 88,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 4,
      "x": 28,
      "y": 190,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "className": "com.holycityaudio.SpinCAD.CADBlocks.reverb_roomCADBlock",
      "blockNum": 5,
      "x": 118,
      "y": 130,
      "name": "Reverb_Room",
      "params": {
        "gain": 0.5,
        "krt": 0.5,
        "hpdf": 0.02,
        "inputkap": 0.5,
        "dlkap": 0.5,
        "rate1": 20.0,
        "pout": 33,
        "apout": 34,
        "temp": 35,
        "outputL": 36,
        "outputR": 37,
        "kd": 38,
        "lp1": 39,
        "lp2": 40,
        "lp3": 41,
        "lp4": 42,
        "hp1": 43,
        "hp2": 44,
        "tlp": 45
      "blockNum": 6,
      "x": 118,
      "y": 190,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 1,
      "toPin": "Input 1"
      "toBlockIndex": 1,
      "toPin": "Input 2"
      "toBlockIndex": 5,
      "toPin": "Input"
      "toBlockIndex": 5,
      "toPin": "Pre_Delay"
      "toBlockIndex": 5,
      "toBlockIndex": 5,
      "toPin": "HF_Loss"
      "toBlockIndex": 6,
      "toPin": "Input 1"
      "toBlockIndex": 6,
      "toPin": "Input 2"
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R0x_Stereo_ROM_Reverb.spcdj",
  "comments": {
    "lines": [
      "Pot 1: Low Frequency",
      "Pot 2: High Frequency",
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 141,
      "y": 19,
      "name": "Input"
      "blockNum": 1,
      "x": 29,
      "y": 57,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 29,
      "y": 95,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 3,
      "x": 27,
      "y": 136,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "className": "com.holycityaudio.SpinCAD.CADBlocks.rom_rev1CADBlock",
      "blockNum": 4,
      "x": 141,
      "y": 85,
      "name": "ROM_Reverb_1",
      "params": {
        "gain": 0.5,
        "kiap": 0.5,
        "nDLs": 4.0,
        "kapd1": 0.6,
        "kapd2": 0.5,
        "kfl": 0.4,
        "kfh": 0.01,
        "lpf1": 32,
        "hpf1": 33,
        "lpf2": 34,
        "hpf2": 35,
        "lpf3": 36,
        "hpf3": 37,
        "lpf4": 38,
        "hpf4": 39,
        "temp": 40,
        "rt": 41,
        "hf": 42,
        "lf": 43,
        "lapout": 44,
        "dacl": 45,
        "rapout": 46,
        "dacr": 47
      "blockNum": 5,
      "x": 185,
      "y": 147,
      "name": "LPF 1P",
      "params": {
        "freq": 0.20171035571672602,
        "lpf1": 48
      "blockNum": 6,
      "x": 116,
      "y": 147,
      "name": "LPF 1P",
      "params": {
        "freq": 0.3239568324310992,
        "lpf1": 49
      "blockNum": 7,
      "x": 140,
      "y": 209,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 4,
      "toPin": "Input_Left"
      "toBlockIndex": 4,
      "toPin": "Input_Right"
      "toBlockIndex": 4,
      "toBlockIndex": 4,
      "toPin": "Low_Freq"
      "toBlockIndex": 4,
      "toPin": "High_Freq"
      "fromPin": "Output_Right",
      "toBlockIndex": 5,
      "toPin": "Input"
      "fromPin": "Output_Left",
      "toBlockIndex": 6,
      "toPin": "Input"
      "toBlockIndex": 7,
      "toPin": "Input 1"
      "toBlockIndex": 7,
      "toPin": "Input 2"
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R0x_Stereo_Plate_Reverb.spcdj",
  "comments": {
    "lines": [
      "Pot 1: HF Loss",
      "Pot 2: not used",
  "potValues": [
    99.0,
    100.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 135,
      "y": 16,
      "name": "Input"
      "blockNum": 1,
      "x": 48,
      "y": 66,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 48,
      "y": 104,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "className": "com.holycityaudio.SpinCAD.CADBlocks.DattorroPlateReverbCADBlock",
      "blockNum": 3,
      "x": 135,
      "y": 77,
      "name": "Dattorro Plate",
      "params": {
        "gain": -4.0,
        "decay": 0.74,
        "damping": 0.71,
        "bandwidth": 0.47
      "blockNum": 4,
      "x": 135,
      "y": 139,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 3,
      "toPin": "Audio Input L"
      "toBlockIndex": 3,
      "toPin": "Audio Input R"
      "toBlockIndex": 3,
      "toPin": "Reverb Time"
      "toBlockIndex": 3,
      "toPin": "HF Loss"
      "fromPin": "Audio Output L",
      "toBlockIndex": 4,
      "toPin": "Input 1"
      "fromPin": "Audio Output R",
      "toBlockIndex": 4,
      "toPin": "Input 2"
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R0x_Stereo_Hall_Reverb.spcdj",
  "comments": {
    "lines": [
      "Pot 0: Pre-Delay",
      "Pot 1: Reverb Time",
      "Pot 2: HF Loss",
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 135,
      "y": 16,
      "name": "Input"
      "blockNum": 1,
      "x": 19,
      "y": 101,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 19,
      "y": 139,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 3,
      "x": 135,
      "y": 73,
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "output": 32
      "blockNum": 4,
      "x": 20,
      "y": 180,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "className": "com.holycityaudio.SpinCAD.CADBlocks.reverb_hallCADBlock",
      "blockNum": 5,
      "x": 135,
      "y": 130,
      "name": "Reverb_Hall",
      "params": {
        "gain": 0.5,
        "krt": 0.75,
        "hpdf": 0.02,
        "inputkap": 0.74,
        "dlkap": 0.71,
        "rate1": 20.0,
        "pout": 33,
        "apout": 34,
        "temp": 35,
        "outputL": 36,
        "outputR": 37,
        "lp1": 38,
        "lp2": 39,
        "hp1": 40,
        "hp2": 41,
        "tlp": 42
      "blockNum": 6,
      "x": 109,
      "y": 191,
      "name": "LPF 1P",
      "params": {
        "lpf1": 43
      "blockNum": 7,
      "x": 178,
      "y": 191,
      "name": "LPF 1P",
      "params": {
        "lpf1": 44
      "blockNum": 8,
      "x": 133,
      "y": 250,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 3,
      "toPin": "Input 1"
      "toBlockIndex": 3,
      "toPin": "Input 2"
      "toBlockIndex": 5,
      "toPin": "Input"
      "toBlockIndex": 5,
      "toBlockIndex": 5,
      "toBlockIndex": 5,
      "toPin": "HF_Loss"
      "toBlockIndex": 6,
      "toPin": "Input"
      "toBlockIndex": 7,
      "toPin": "Input"
      "toBlockIndex": 8,
      "toPin": "Input 1"
      "toBlockIndex": 8,
      "toPin": "Input 2"
These all sound great.
Is "ROM" a second option for Room or is it a separate option?
The hall reverb seems a little small for a hall but doesn't sound bad.
The ROM verb is the stereo version of the two "ROM" verb blocks. Not a Room verb.
The Hall verb uses the Designer's "Hall Reverb" block and is about as big as it can get. Below, I swapped out the Hall verb block for the Adjustable Reverb block to get a bigger effect . . . .
R0x_Stereo_Hall_Reverb_02.spcdj
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R0x_Stereo_Hall_Reverb_02.spcdj",
  "comments": {
    "fileName": "R0x_Stereo_Hall_Reverb.spcdj",
    "lines": [
      "Pot 0: Pre-Delay",
      "Pot 2: HF Loss",
  "potValues": [
    39.0,
    0.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 135,
      "y": 16,
      "name": "Input"
      "blockNum": 1,
      "x": 22,
      "y": 117,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 22,
      "y": 155,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 3,
      "x": 135,
      "y": 73,
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "output": 32
      "className": "com.holycityaudio.SpinCAD.CADBlocks.reverbCADBlock",
      "blockNum": 4,
      "x": 135,
      "y": 131,
      "name": "Reverb",
      "params": {
        "LFOAIs0": true,
        "LFOBIs0": true,
        "LFOAIs1": false,
        "LFOBIs1": false,
        "gain": 0.5,
        "hpf4": 33,
        "lpf4": 34,
        "temp": 35,
        "rt": 36,
        "iapout": 37,
        "outputL": 38,
        "nAPs": 4.0,
        "kiap": 0.5,
        "nDLs": 4.0,
        "klap": 0.6,
        "kfl": 0.4,
        "kfh": 0.01,
        "lfoSelA": 0.0,
        "lfoSelB": 0.0,
        "rate1": 20.0,
        "rate2": 20.0,
        "hpf1": 39,
        "lpf1": 40,
        "hpf2": 41,
        "lpf2": 42,
        "hpf3": 43,
        "lpf3": 44,
        "outputR": 45
      "blockNum": 5,
      "x": 178,
      "y": 191,
      "name": "LPF 1P",
      "params": {
        "lpf1": 46
      "blockNum": 6,
      "x": 109,
      "y": 191,
      "name": "LPF 1P",
      "params": {
        "lpf1": 47
      "blockNum": 7,
      "x": 134,
      "y": 257,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 3,
      "toPin": "Input 1"
      "toBlockIndex": 3,
      "toPin": "Input 2"
      "toBlockIndex": 4,
      "toPin": "Input"
      "toBlockIndex": 4,
      "toBlockIndex": 4,
      "toPin": "Filter"
      "toBlockIndex": 5,
      "toPin": "Input"
      "toBlockIndex": 6,
      "toPin": "Input"
      "toBlockIndex": 7,
      "toPin": "Input 1"
      "toBlockIndex": 7,
      "toPin": "Input 2"
I like the last option here.
Re: R03 (stereo shimmer verb) . . . .
I just finished putting all 8 of the reverbs into an EEPROM to do a final in-circuit test and seems that the only one that presents a problem is R03 - the Shimmer verb. It audits fine in SpinCAD, but in the Binaura, the shimmer aspect goes into runaway rather quickly. I'm looking for the solution now.
Yes, I like the second version of hall better.
Stoked to hear its mostly functioning on the eeprom. Keep me posted.
Just finished up trying several things and am currently unable to stop the shimmer aspect of the shimmer verb from running away. Tried six different ways to achieve a shimmer, burned to EEPROM, but they all run away when in stereo for some reason. On the bright side, we did get 15 out of 16 working patches.
