Blue Shoe Gai Pan trimmer bias
Lang1320
Board has 3 trimmers. I need a High School shop class level explanation on how to set the bias trimmers, please. I understand the transistor inconsistency and thus the need for trimmers vs fixed resistors. Setting by ear is not an option. What voltage? Where do I connect the leads? 1/2 supply voltage and "typical" settings are not applicable. I'm looking for specific settings on a specific board.
Not sure if this is too late, but half supply voltage is applicable for trimming JFETs. Since the supply is 18V due to a charge pump, measure about 9V on each JFET Drain. Look up "J201 pinout" to find which pin is the drain. Hope that helps!
Start with Q1 and go in order, some have suggested biasing a little hotter like 11v, set mine at 9v and sounds great
