p_wats
Another weird delay is low on the list of things i need, but high on the list of fun, so here we are.
I figured I'd mess with this one a bit and see if I could go even weirder. Some notes on the stock build:
The second footswitch is a momentary stomp wired to the corresponding knob (with the same wavy symbol), which basically jumpers the delay time, to make for weird blips from fast to slow. It's wired to an a250k pot (this value is probably overkill, but seemed to give a good range of fun sounds), all in parallel with lugs 1&2 of the delay knob. Works well when the repeats are running away.
The enclosure is salvaged and beat up, so I wasn't too careful with the spray (though I never am). Lots of fun with this one. Hoping to do a video or something soon!
Lots of room in there if I decide to add a relay board, but for some reason I still bunched everything up on the one side in my excitement. Oops.
- I had some ticking with the 4558s I tried, so I went with a TL062, which cured that
- I found the modulation worked with a tayda LDR + LED, but the wave knob had the most variation with a vactrol, so I'm using that for now
