DiamondFlesh
Hi There!
I’ve just build the Thermionic deluxe and everything is working as it should be. However, when I set the tight knob below half, the pedal is going to oscillate. Setting the trimpots on zero won’t solve the problem. It happens on both channels. Ive measured all resistors and readings are fine. Also when I disengage the pedal, the on/off led is still bleading so I assume it’s a voltage problem? Any help is much appreciated!
