Danbieranowski
Hey all,
I've tried a few different things with this, and all have failed for one reason or another.
I just want to add a blend to a Promethium.
If I use the Promethium board alone (no blend mod), it sounds and works great.
I've tried the GuitarPCB Buff n' Blend, but it oscillates. No oscillation if I don't run it through the send and return of the Buff N Blend, so it's definitely the BNB causing the issue.
I've tried a Mini-Mixer (little parallel mixer), with the idea of giving him one volume knob that's his clean signal, and one volume knob that's the HM-2 so he can mix to taste. The problem that I have with this is:
A) I get a little bit of volume or tone loss with the Mini-Mixer (found here: http://www.generalguitargadgets.com/effects-projects/boosters/mini-mixer/).
B) I can't think of a way to wire it up where, when switched off, the pedal is just standard true-bypass, but when on, I can feed the clean input signal to one pot of the Mini-Mixer, and feed the output signal of the circuit to another pot of the Mini-Mixer.
I'm not sure what else I'm not thinking of here, but I feel like there's a glaringly obvious way to do this, and I just need a sanity check from the PedalPCB folks. Any help would be appreciated!
