Awesome, thanks! I appreciate it!Use the L78L12. Do NOT use the -5.0. That is a 5 volt regulator, you need 12 volt.
Does the board differ a lot from the build docs? I just ordered one and also sourced and ordered most is the parts.I’m getting set to build a Valhalla but had a question about IC 5. The board says it should be a L78L12 but the build docs show a LM2940CT-12.
Would either one work?
Also, would a LM2940CT-5.0 work in place of the -12? (If that’s the correct part)
That was one of the few components I haven’t got yet so that will workout pretty good. Thanks!The only difference is that the board was changed to fit the smaller L78L12 rather than the larger LM2940CT-12.
The LM2940CT-12 can still be used, just install it backwards compared to the L78L12 footprint on the PCB.
