So I’ve built a true bypass switcher with one tuner loop and four loops. I bought four common anode bicolor leds for the four loops. I want to wire the led to the 3PDT so that the led is red when bypassed and green when engaged versus the one on or both on setup. I could hook one side up to the normal led spot on the footswitch (lug 2) with ground in the middle on lug 5 which would make it green when engaged. My question is instead of wiring the red right to ground so it’s always on, could I wire it to lug 8 (lug 8 is jumped to lug 1) so that it’s connected to ground when the loop is bypassed? My only concern is that when the loop is engaged, it’s not connected to ground but it’s still jumped to lug 1 which is the loop send. Would that cause any issues? Would the loop send be connected through the led to ground or the cathode?
