Informant Overdrive - No Signal (Buffer or Effect)
YakSabbath
Hello! I am currently working on an Informant Overdrive but ran into a snag – LED works but I have no signal through the pedal on buffered or effect mode.
Strangely I am getting 17V on the second opamp but not the first, I have switched the chips around with same results to it must be circuit related, see voltages below:
IC1
1 - .01V
2 - .01V
3 - 7.22V
4 - 0V
5 - 7.22V
6 - 0V
7 - 0V
8 - 0V
IC2
1 - 8.81V
2 – 8.8V
3 – 7.22V
4 – 0V
5 – 7.22V
6 – 8.8V
7 – 8.84V
8 – 17.52V
IC3
1 – 9.1V
2 – 4.56V
3 – 0V
4 - 0.17 V
5 - 0.38V
6 – 4.38V
7 – 6.81V
8 – 9.1V
I seem to be getting noise floor – the volume and drive controls give proportional noise when dialed up and down, cut control seems to filter the noise, seems like the latter section of the circuit is functioning but no signal getting through IC1
Using a MAX1044 for voltage charge pump with bead of solder across jumper pad as per instructions, I have tried two different chips with same results
Picture attached of back and front of board attached, i have reflowed twice already
Any help would be appreciated – thanks!
Further to this, I have used an audio probe and the signal stops in opamp 1 (obviously - there’s no voltage)
I pulled ICs out and read NO continuity between pin 8 on each (as per schematic they should be in parallel with each other)
On underside of board I put a jumper lead between solder pads in case of a bad trace and now I get continuity, however I still have NO opamp voltage on IC1! Is there a bad capacitor somewhere in the supply side messing things up?? Is the opamp socket faulty??
Have you tried swapping Op Amp's?
