Fuzzonaut
Muff? Drone? Gimmie, gimmie gimmmie!!! (No matter what time it is.)
I just had to try this one. The PCB is from Inverted Cross Audio. I didn't pay attention when ordering, usually I stay a few miles away from anything SMD (= Super Mühsame Dinger) as we have a smd J201 in there (no through hole possible). Took quite some fiddling, but seems like I successfully soldered that tiny thing correctly.
We have a clean blend, Tone and Scoop, clipping options in the first and second stage (si/none/LED) and a feedback potentiometer for the sustainer drone mode. There are 2 drone modes, the other one turns the pedal more or less into a drone/noise synth.
The layout of the PCB was for a 125B, with the option to put a Drone on/off toggle switch somewhere on the side .... ?!?
Well, nope. I put the whole thing into a BB and wired the Drone on/off switch as a footswitch with an on/off LED.
Sounds pretty good (2N5088 transistors, might play around here) and delivers a lot of different toanz and noizes.
![drone-m.jpeg drone-m.jpeg](https://forum.pedalpcb.com/data/attachments/77/77408-84687538eb06b3b63ef96f09deed9aed.jpg)
![drone-m-g.jpeg drone-m-g.jpeg](https://forum.pedalpcb.com/data/attachments/77/77409-632afa7f359c0cfb71308de60d0c2ba5.jpg)
