...I think I am going to change my assembly process.
I have a couple of builds that have unexplainable issues that were never solved.
So rather than wait until the moment of truth when power is applied, I'm going to pursue an incremental assembly process.
I have typically installed components by class. Usually resistors then caps, regulators....
I think going forward I will try as best and as practical to build and test the circuit from one end to the other.
Start with the power supply and make sure it is delivering appropriate power to its end point.
Then I'll build out the rest of the circuit, testing along the way.
This approach flies in the face of economy of motion, but time is saved on the backend by trying to analyze where a fault(s) lies in the entire system.
