I’m trying to better understand why biasing sometimes works and sometimes doesn’t work.
I have a practical question about the Sandspur / Sunflower PCBs. I’m trying to use 2n1308 NPN germaniums in the Sandspur and noticed that the collector voltage of Q2 can’t get below around 5,5V. Bias and sundial to minimum. Also the range of max/min is just over 1v with somewhere in the 6-7V on the upper end of the trim and sundial.
These 2n1308s are around 200 HFE, with a VBE of 0,358V, Iceo 84,3uA, Ib 4,58mA.
The silicon BC546A has a similar HFE with VBE around 0,76V, Ib 4,1mA. These bias correctly.
So I’m trying to understand why the 2n1308 can’t bias correctly without modification to the circuit? How to calculate and explain this and what needs to be changed and why? Is there a formula on how to calculate this?
The Sunflower is identical to the Sandspur, only the inverter is in the Sunflower.
2n1305, 2n1309 PNP germaniums etc bias correctly in the Sunflower. Is this related to the NPN germaniums?
