Will the BBW Sonic Stomp work with an off-spec pot?
MBFX
I don't use many B50K pots, so I only bought two. One of them measures 37K. Think that will be useable? Can I swap out for a B100K?
You can use it but turning the pot all the way counter clockwise will have less range than a pot closer to 50K. For the opposite case - all the way clockwise - it doesn't matter. 100K will technically work but may not sound right.
I would do that, but I'm out of 100K resistors
What have you got close to 100k?
100k pot + ...
110k = 52k38​
102k = 50k495​
91k = 47k6​
82k = 45k​
What resistors have you got that you could solder together in series that gets you close to 100k?
Calc it out here. You could solder a couple of smaller value resistors together and then bridge that over the 100k-pot's 1&3...
Don't forget, the resistor across the pot-lugs trick does change the taper; I read that in The Secret Life of Pots, IIRC.
Hey, I get it.
I make those suggestions, but I've got a few builds on standby where I'm missing ONE resistor (390k, why is it always 390k?);
even though I had some 1/8w, I'm loath to use them (or stand a 1/4w when the layout calls for 1/8), but now I've run out of 1/8w 390k too...
