The Week on the Breadboard: The Emperor of Tone
I want to ask everyone about their preferences w.r.t. the charge pump.
1. No charge pump. Run it on 9V or 18V. That's the schematic in post #13.
2. Optional charge pump. The charge pump can be installed or not. Or you can put a voltage switch on the board. If the charge pump is not installed, then you have option #1.
3. Split rails. That's the schematic in post #1. Charge pump is mandatory. Must run on 9V only.
I don't have a strong preference one way or the other. They all have advantages & disadvantages and none of them are show-stoppers. #1 is the minimalist solution. #2 is the most flexible, but also has the highest parts count. #3 removes one electrolytic cap from the audio path in each channel (C6 & C16).
If there's no real sound advantage to the split rail design I would vote for option 1, no charge pump.
The advantage of split rails is there's no Vref. Everything that connects to Vref in #1 or #2 connects to GND in #3. We don't need C6 or C16 to block DC, so they are removed. Theoretically, every component that the signal passes thru colors the tone whether we want it to or not. So it should sound better with those two caps removed. I doubt any of us would hear the difference.
Help me understand: what is the benefit of running the channels in parallel? Both channels do basically the same thing. Have you tried it?
I have not tried it. My friend wanted to know, I believe he wanted to be able to blend the two together.
I didn’t mean to distract from the Charge Pump talk.
I personally like the bipolar power option. More complex power supply, but allows simplification of the audio path. Feels more hifi. 9 and 18v KOT has already been done, bipolar is unique (at least from what I’ve seen).
You could go the bipolar route, but then add space for a couple LDOs to drop it down to say +/- 5v, so you’re closer to the original single 9v rail (for more drive/less headroom), but still have the benefit of split rail power.
I have Rhythm channel on a breadboard now with +/- 9V supply.
I only managed to play for a moment, so I can't say much. Just a quick one - with +-9V power supply there is quite a large output signal (although it depends on the Hard pot setting). Also - for me - a lot of lows with the 470n connected (Bottom sw). Hard pot - effect of the pot is subtle.
I'm opting for 16mm pots and sub-miniature toggles on this one. The non-threaded sub-miniature toggles look cleaner and are very low-profile, allowing for more space and a cleaner layout.
Mystery solved.. before I wrote the above I checked output signal on the oscilloscope. And the Hard potentiometer made quite visible impact on the singnal amplitude but the I could not hear much of a difference in the headphones. Now I know why.. even with the Hard maxed the output signal level is quite large and it easily drives the amp into clipping. Turn down Vol to 9 o'clock or so and voila.. now I can hear the difference.
I put a 9/18 volts switch in mine, and I much prefer 9 volts. Guess I just like it a little dirty.. So I'd say pull the charge pump out completely. If you must have a charge pump, I say go with dual +9v/-9v rails!
