Here are a few pedals that I recently made. The Straylight is a fabulous Univibe. I really like the cancel feature. The Paragon is made with 1S1588 and BA282 diodes. The splitter is a utility pedal.
Thanks! The splitter design was pure luck. I messed up on a UV print, but the face plate hides it nicely. The knobs were accidentally purchased, but it all worked well!
How did you mount the smaller LED lenses? I’ve seen that the larger ones can be mounted via a thread on nut but I have only seen the snap in versions of the smaller lenses, and I’m not sure how those are secured to the enclosure.
I think he means how does the bezel stay put in the drill hole. These will kind of wedge themselves in the hole if your drilling is precise. If it's not, a bit of hot glue does the trick.
