another pal m-800 question
Kind of. Start with Q1 and bias to half the voltage (approx) and go down the line. Then repeat (you'll need to readjust nearly all of them again). Then tweak by ear.
I'd start with Q1 anyway but you might need to adjust them twice because they're all running on the same power rail. Nothing fancy to it, though. Don't forget the last trimmer on the bottom right is just a tone adjustment lol.
edit: buddybeaten
Got it . Thank you.. That's what I did. For me, DEFINITELY, a circuit needing much more focus on dialing in the trimmers to getting it to sound right. Tweaking the trimmers ever (EVER!) so slightly will change the sound a bit so I'd go back several times adjusting the trimmers. Mine works ..... but like others have said the tone control section has minimal effect on the pedal (tho they do work just subtlety). Even tried a few other postings of trimmer voltages just (i guess) not hitting my higher expectations of what I thought it should or would sound like. I know it's not a high gain monster and it doesn't sound shitty but like I said my expectations were probably too high. Some time I'll try and go back to it see if I can coax more out of it or maybe I'll come across some voltages that get it where I'd like it. Time will tell.
Thanks for taking your time to read and reply really appreciate it only wish I had more knowledge so I could do the same .
take care and ....let's build on.
(got 3 more to do and can't wait for the byzantium since I tried 3 or 4 other flanger builds with no luck ,most likely errors on my side)
