Uni-Vibe and Surprise Preamp (AionFX Straylight)
mkstewartesq
If you have followed my past build reports, I’ve been hunting for a good vibe sound while steadfastly trying to avoid building an actual optical vibe. Even though I’ve built easily more than 50 pedals now, I think the thought of all the special parts sourcing – as well as parts I never worked with before like incandescent lamps – just left me a little a-scared. So I built numerous pedal that had some sort of vibe functionality, like the Lectric-FX Karaoke Chorus, PPCB Circulator, GPCB’s The Vibe, and a vero build of the Runoffgroive Tri-Vibe. Some were better than others (of the ones named above, the vibe on the Circulator is my favorite) but I finally decided to just bite the bullet, put on my big boy pants, whatever metaphor you want, and just do it.
The Build: I went with the AionFX Straylight because I was daunted by the build and, given all of the biasing required, I really needed a little more of the handholding that Kevin’s build docs give. It took a while to source the parts and then when it came time to build, I actually took some advice @Big Monk gave in another thread – namely, no matter what, never rush building a vibe. So I took things very deliberately, and I also studied a lot of pictures of other Straylight builds on this forum and elsewhere to get a better sense of installing the lamp, positioning the LDRs, etc.
I also bought AionFX’s custom reflective light box to go around the lamp and LDRs – I really think he should just throw this in with the PCB as standard and charge a couple bucks more because it really is a necessary part of the build. I found it incredibly useful – although, as happens with manufactured things, mine was not cut exactly right for all of the edges to fit flush, but some judicious use of some metal files on various edges eventually made it all work.
Let me preface the following by saying that were it not for AionFX, I would not be here in this forum or in this hobby. Sometime in early 2022, I got a bug up in my ass to own a Rangemaster and decided to build one even though I had never soldered in my life and I could not tell you the difference between a resistor and a capacitor. I bought his Radian kit and the instructions were so awesome and helpful as far as explaining components, how to install them, etc.that I immediately moved on to PPCB, building PCBs and sourcing my own parts. My love of the hobby has grown since then, and I’ve gotten to know all you find people. So I owe Kevin a lot.
That being said, I LOATHE AionFX’s design choices around their breakout boards. I get why he does it (especially so these can be leverage as kits) but I find them so incredibly counterintuitive and, in a build like this one where everything is incredibly tight, what a freaking nightmare it was to connect 16 wires in the box to stomp switches where it should’ve been something like 8. And I’m not even 100% sure I can tell you the purpose of each wire. Anyway, it’s AionFX’s world, and I am just living in it so I will hush now.
The Sound: I like it a lot – but I may need to append this review later because I am obsessive about biasing modulation effects (I re-biased my XC-Phase approximately 200,000 times over a six month period and still I’m not sure I have it right). And as @Gordo noted, biasing vibe is like going to the optometrist - you can get paralyzed with having to choose between minuscule differences. I shall continue to dither her until around Thanksgiving.
But so far the vibe sounds like what I expect a vibe to sound like, as does the chorus (really a phaser) - I do think the sound feels a little more thin (i.e., not much low end) than I was expecting, but I have zero experience with a real vibe so I will trust that this is just a shortcoming of the original circuit since Kevin seems to be a real student about the historical aspects of the circuits he re-creates.
But what really surprised me is that, so far my favorite thing about the vibe isn’t actually the vibe – it’s the “cancel” mode, which allows you to replicate the original (non-true bypass) bypass function of the Uni-Vibe, where the lamp was switched off but the signal still passed through the circuit. The build docs say that this adds a “subtle coloration that some people like” – well, I freaking love it. It basically sounds kind of like an Echoplex preamp, and just seems to add a bit of punch and sparkle to my Telecaster. Frankly, I’ve played around with that more than I have the vibe and I’m considering moving this pedal to the front of my chain just for that effect. (Since “cancel” turns off the lamp, I can leave the pedal powered on without worrying about shortening the lamp lifespan). I have a Clandestine Preamp, which is an echoplex preamp, but I greatly prefer this one because it seems to have a lot more headroom.
The Enclosure: the enclosure is just a Hammond enclosure polished by hand, with a film free decal and an application of clearcoat. Sunnyscopa changes their glue formulation a year or so ago so that it requires much less heat to cure (I ruined several decals using my normal curing regimen before figuring out the glue had changed) but now that I’ve cut my oven curing time in about half to compensate, the decals are coming out much better again. That’s a long-winded way of saying those a little specks in the picture are dust, not flaws in the decal.
As far as the name, I just wasn’t feeling particularly creative and just called the damn thing a Uni-Vibe because that’s what it is. Coincidentally, while building this, I ran across a guy on Facebook who is also building a Straylight; he mentioned to me that he was going to call his “Uni-Brow”. Which I think we can all agree is a far better name, but it was too late for me to steal it.
Mike
I totally agree that this is a fantastic pedal. It is always on for me, mainly with the preamp running, but I also have the vibe running.
I also agree about the AionFx breakout boards. My pet peeve is to have to troubleshoot a pedal. You find the problem, fix it, and rock it outside of the box. However, when boxing it, you break a wire to the breakout board and create a new issue. This scenario has happened to often to count.
That being said, AionFx does a great job and has some great projects. This project is one of their best.
Very nicely done. One of the anomalies of the original is that it tends to thin out the sound overall. With Trower and Hendrix it’s hard to tell in a live setting because they often used fuzz or boost along with it. Heart’s “Sing Child Sing” from their first album gives you a bit of the difference from dry to vibe, it sounds like Roger Fisher recorded in one take or at least kept the same amp settings.
I think more modern vibes try to undo that effect which may or may not be beneficial.
I'm with you 100% on this. I ended up just fabbing some PCBs that match up to his kits DC and Boss slim line jack board and bought a bunch of premade jst connectors to speed up the build process and lessen my annoyance.
Mike:
Love your build and the write up. Your enclosure is outstanding, I’ve tried decals, watersides, even bought a Cricut machine and they have all been pretty poor. I had not heard of Sunny Scopa before, I ordered some product from Korea and I’m going to give it a try. I’m in the process of building a Straylight, a couple of questions, do you use a special oven or toaster oven to heat your pedals? How many coats of clear do you spray after?
One other question, I suck at the graphic programs, would you be willing to share a file of your graphic for the Straylight? If you wanted to delete the layer with the Uni-Vibe name that would be fine.
Anyway, great build, thanks for sharing the information.
Best,
Scott
Mike:
Best,
Scott
Thanks, Scott:
1. I just bake in the regular oven because I don’t have a toaster oven. I’ve heard people mention that they normally stay away from using the same oven that they cook in but I’ll be candid that I’m not clear on what the supposed risk is and, even if there is a risk, I bake one decal on average a month, so it’s not like I’m using this every day and contaminating the oven with chemicals over and over again. My first bake is about five minutes at 235°F, then I remove the film and bake it for about another 15 minutes (since I put clearcoat on, I probably don’t even really need to bake it that long).
As far as the clearcoat – I usually only put one coat on because it doesn’t need to be maximum protection like a commercial pedal. That being said, on this specific pedal, either the weather wasn’t cooperating or I put on too thick of a coat because it had a bit of solvent pop (little bubbles that look like there was dust in the finish) so for this one I actually had to sand the clearcoat a little bit to get those blemishes off and then bring it back up to a shine with rubbing compound. I normally don’t have to do that.
2. I don’t have a problem sharing this art – although, as you figured, I probably don’t want to be seen distributing art that has a trademarked name in it, so I would probably remove that one word. Why don’t you PM me with your contact information and let me know if you’re looking for just the PDF ready to go to print out or if you want the Adobe illustrator file because you want to edit it further?
M
Hey Mike, thanks for the quick reply, I really appreciate it, also appreciate the additional insight on the baking process. I guess if you could send me the Adobe Illustrator file, I’ll get my daughters boyfriend to add a name (won’t be Uni-Vibe), I’ll send you a picture when it’s complete. I use GIMP, as I said I suck with the graphics programs. I originally tried to PM you but the site wouldn’t let me, I guess because I’m a relatively new member? You could use this email address [email protected]
Thanks again, I really appreciate your help.
Scott
Scott
Sent!
M
Funtastique!
Superb build.
I saw somewhere an amp (replica of a Matamp, IIRC) named Unibrow, even aping Matamp's "Green" bubble-font.
Frankly, IMO, "Uni-brow" is a fugly name — I think you were right to just use the Uni-Vibe original name for your personal build.
@mkstewartesq
Hey Mike, what an amazing job you have done. I have done maybe 15 - 20 of these and the break out board is a pain in the ***. I also hate the fact that Kevin’s designs all use wima 1uf films that cost $20 each. But, he is a bloody legend and the detail in his doc is amazing.
I’m really curious about this sunnyscopa decal you use. I’ve never heard of it ! I use regular water slide, but dam your enclosure is amazing man.
Could you enlighten me as to where you get it from please.
@mkstewartesq
Hi – thank you for the kind words!
I use the Sunnyscopa film-free decals for LaserJet printers. I normally buy it from Amazon (US) but Amazon is not currently offering this product so I will have to hope that it comes back in stock before I run out of my existing supply.
However, it may not come back in stock at Amazon. Approximately a year ago Sunnyscopa shifted to selling directly on its own website, with shipping from Korea (which substantially increases the costs for me in the US). Here is a link to the product on their website, as well as a link to @MattG 's thread that was just posted yesterday - it gives an excellent overview of the process for applying the decal now that Sunnyscopa has changed the glue formulation, such that it now requires a different application method and a shorter curing time.
Mike
They have definitely risen in price on Mouser in the past few years, but I recently saw Tayda is carrying them now for 0.49 each and they have a pretty good stock at the moment, if that helps!
You could also sub with MLCC (https://www.taydaelectronics.com/1uf-50v-multilayer-ceramic-capacitor.html) which should be cross-compatible in pretty much any application as well.
Mike
Hey Mike, thanks for the quick response.
I priced it up with delivery to the UK 😳 think I may have to stick with water slide 🤣
Thanks Kevin, I’ve always been wary of straying from your build docs as they are so detailed - but now the man says it’s ok 😂
Understood. Buying directly from Sunnyscopa makes the same 20-sheet pack twice the price I paid when buying from Amazon, because the shipping to the U.S. is as much as the actual decal paper itself. And that is before adding in whatever tariffs the US might have in effect when the order actually ships to me. So I plan to just be very careful with my existing stock for now.
