Hi, finally my first post here! I've been building since a short while so still a novice. Made some fuzzes wich all worked out very well (besides having a transistor wired wrong, once mixed up resistors K for R, had a stupid ground enclosure problem, all was fastly resolved. But now I'm really stuck.
Build this 2 pedal in one housing and the RM side is working fantastically, the fuzz face side however works in bypass but when engaged only white noise. I've been checking the wiring and parts placement at least 10 times. I even changed out the 3DPDT switch and the transistors (2N1308). Tried a probe but don't know exactly which points to contact to follow the signal. This morning I've rewired the complete pedal... no change
I suspect there is something wrong with the jack sockets.
Can anybody help me in the right direction, to solve this??
