Ok so I am having some weird issues with a new Phase ll build.
First time I fired it up my LED was glowing nicely. Left trimmer (1k) would adjust brightness and right LED would adjust brightness as well? No pulsing from the LED.
After a few times going back to it the 1k trimmer came apart. The white dial popped off the top.
So I unsoldered and pulled it and put a new one in.
Since then the left trimmer doesn’t do anything and the LED wasn’t really glowing at all. If I would squeeze the 1044 IC and socket between my thumb and fingers the LED would come on. So
after looking for possible solutions on the forum and inter webs I pulled the 1044 and prepared to swap in a 7660 which is the only other similar IC I have. But as I pulled the 1044 the LED came on. If I try to put something in that socket the LED goes very dim. With the IC in the 10k trimmers came brightens the LED.
I do get sound through it and I could hear some phasing in a dark room with a flashlight on the LDRs.
I can measure voltages and audio probe but I’m not really sure where to start and I’m hoping someone may have some guidance.
I measure all components prior to populating the board so I’m pretty confident it wasn’t just a wrong value resistor or capacitor.
Edit: I don’t have to pinch the 1044. If I place my finger over the soldered pins on the bottom of the board the LED comes on. I thought it might just be poor soldering but I reflowed those and same issue.
Any help would be sooo appreciated. I am building this for a friend and I have a nice UV enclosure ready to go!
