Guyatone PS-021 (AionFX Meridian)
MichaelW
5.00 star(s)
Ok, here we go again......on another roll with compressors!
I'm also waiting for @Robert to get the Uber-Squeezer boards in. (Actually I don't think thats what it's called but its the PPCB of the MXR SuperComp:))
The Aion Meridian is another compressor that I never got around to building, mostly because I wasn't all that interested in the "exciter" aspect.
But after reading the build docs a little closer the exciter is easily defeated by leaving the control at noon.
Anyway, this circuit can basically be viewed as 3 separate circuits. At the front end is an almost direct copy of a Dyna Comp compressor circuit with the exception of converting the use of a 3080 IC into a LM13700. (Which is essentially 2x 3080's. And incidentally, the best price I've found for the LM13700 is right here.
Stupid cheap and I've been throwing a couple onto each order.)
The second section of the circuit is the "exciter" which is similar to the BBE Sonic Stomp. At noon it's neutral, CW adds even order harmonics and CCW adds odd order harmonics. It's rather subtle but the effect is magnified under gain. So I can see dialing up a gain tone and fine tuning it with this control.
The 3rd and probably most USEFUL section is a BMP style tone stack in a single "Tilt" style knob just like on a Muff.
All 3 of these sections work remarkably well together and it feels and sounds well integrated as opposed to "tacked together".
I went "commando" with this build and used a "raw" enclosure. With the tariffs lately, I have to be more careful with what I order from Tayda and when I'm in between cycles of my "retired hobby budget" I've been grabbing raw enclosures off Amazon in a pinch.
And oh by the way, if you plan on building this board, make sure to get some of the "small footprint WIMA 1uf caps". Or you can use poly caps or greenies and just leave the legs long. The default footprint for the 1uf film is pretty skinny. I wouldn't have any problem using C0G 1uf caps or even XR7 MLCC's either, but I just got a buttload of the skinny WIMA's so thats what I used.
So I have to say, again, like my Creamery Compressor build I really wasn't expecting much from this except to add to my collection of compressors.
But holy crap AGAIN, it sounds REALLY good! This is another pedal that I think bass players will really dig. (You can also build the PS-020 Bass version on this board with like 5 component changes).
Built stock, the compressor circuit is more laid back and acts more as a limiter. But there's a "more sustain" mod which is a single resistor and a pot change which I did.
My initial impression is that "this sounds like a really really really clean and quiet Dyna Comp". It's got that Dyna Comp sound and feel. Even the Level and Sustain knobs work like a bone stock Dyna Comp. (E.g., you can set the knobs at 3 o'clock level and 9 o'clock sustain for the "Nashville session player setting" and it sounds spot on).
The addition of the "Color" knob, (tone control) really lets you dial in the tone of the compressor which you can't do on a Dyna Comp.
The Exciter knob I've messed with a little and tbh, I don't really know how to use it. For now it's staying at noon, or inactive.
The overall tone of the pedal is big and full and (can be made) warm and musical. With the "more sustain' mod it's got a TON of compression on tap.
But I've got it dialed back quite a bit and it's a lovely "always on" pedal. Unlike the Dyna Comp and most of the other Dyna/Ross style compressors I've built, this pedal has a nice, big, rich and full soundstage, just like my General Tso and the Creamery. It has kicked off my Median compressor (Wampler Ego76) off my compressor board for now and it's taken a place as one of 4 compressors I have hooked up at the beginning of my chain. I do have a Dyna Comp build that is pretty stock but it's SOOOOO incredibly noisy and susceptible to power issues that I have to put on my floor pedal board away from everything else so it won't "chitter" at me when I turn it on. But NO MORE! I can get that Dyna Comp sound now thats as quiet as my other compressors. That makes me feel all warm and fuzzy:)
I've been on a quest to build an "as vintage accurate as possible" MXR Dyna Comp. I even snagged a Metal Can 3080 and there's a dude on Etsy/Reverb that sells vintage layout Dyna Comp boards. But now I'm kind of wondering....why? Heh, I'll probably still build it but in the meantime the PS-021 fills that gap extremely well!
Another HIGHLY RECOMMENDED build for compressor users. Especially if you're a Dyna Comp user struggling with the inherent noise floor of the MXR.
Lucky you! I think those skinny 1µF Wima film caps may have gone EOL, so you may now have a precious stash.
And of course, thanks again for another great build report!
Nice build !
The Meridian is an always-on tool for me. I tried other compressors, but this circuit does everything i need and more.
Even if i like my pickups, i still often try various EQ settings with the Meridian on bass, guitars, synth, drum machines, etc.
Compared to a GE-7 these Color and Exciter controls are a fastest way to cut or boost some frequencies with good results.
Their range and action are just perfectly calibrated for my tastes.
I still use a GE-7 at the end of the signal chain for minor adjustments, the Meridian is the first effect in the chain and it does a lot of tone shaping before everything else.
Overdrives, distortions and fuzzes dont sound the same without it. It made me discover the benefits of pre-EQing before gain effects.
Built without the extra compression mod, it doesn't have the same attack punch that some other compressors can give.
It does a more subtle effect on the attack which makes it easier to dial and more suited for most situations, in my opinion.
I think it mostly boost or cut mids, it might also do something a bit more subtle than that, but that's how i've been using it for years.
I'm not sure what even and odd harmonics sound like, to my ears it's similar to creating some curves going up or down, centered around the mid frequencies.
I really like how it sounds with this control set somewhere between 9 and 11 o'clock, it kind of cleans up the sound, it's a sharper and more precise tone. If we turn it CW, it gives more of its own character to the sound, more intensity.
In my mind, the Meridian is a great EQ tool, the sustain and compression effects are some interesting bonuses because they're subtle and yet effective, as long as we dont need some extreme attack settings.
When i really want to get some noticeable attack boost, i use a Walrus Deep Six. I wonder if you ever tried it ?
Nice build !
Yup, sounds like we're both using it the same way. I have not tried the Deep Six.
I don't see a DIY option for it.
But it's an OTA compressor designed to emulate the 1176 as I understand.
https://www.mouser.com/ProductDetail/505-MKS2B041001C00KS
There's about 1800 still at Mouser. I don't see that it's EOL. Maybe I should buy some more......
I sure hope you're right. And maybe I'm messing up with the supplier search engines. But recently I have been unable to find any Wima 1µF film caps w/ 5mm lead spacing that have the thinner 3.5mm width at my usual suppliers. A couple months back, I noticed that they were low in stock at Mouser, and ordered some. But now when I look at Mouser and Digikey, I only see Wima 1µF film caps that are ≥5mm thick. E.g., the 505-MKS2B041001C00KS you linked shows as no longer available "in my region". (I'm in NJ US). They have also been out of stock at Tayda for a while. Hopefully it's a temporary stocking glitch. But if they're indeed gone, I can only note that they're a fair number of AionFX PCBs that only fit those skinny Wima 1µF film caps...
Not available in NJ but I can get them in Florida? That's odd. DM me if you want me to order some for you.
So the Wima 1µF 50V MKS2B041001C00xxxx are the skinny (3.5mm thick) film caps.
I just did another big search and just couldn't locate any from my bookmarked electronics suppliers.
That said, I don't see any sign of them officially going EOL, so I can't explain why they're unavailable.
So @owlexifry - thanks for the tip, those look to be the best option right now w/ the new US tariff rates. (I'm leery of Alibaba.)
And @MichaelW - I really think you might have a valuable stash! Indeed save them, their value might jump soon.
Yah, I've been chatting with @Audandash (who first clued me in on the @100 pricing). We both recently grabbed 100 from Mouser.
I usually only keep about 10-12 of the skinny WIMA on hand for skinny pads. (Mostly AionFX boards)
I WAS just planning to use them on everything since it takes me a while to go through 100x 1uf caps. But now I'm thinking if I go back to only using these skinny WIMA where absolutely necessary, I can stretch this batch out for years hahah.
Here's what Kevin from AionFX said when I asked if he knew anything about them.
Yeah, WIMA issued a notice to suppliers sometime in March that their mylar supplier was having issues so the 3.5mm (50V) ones would be temporarily unavailable. They didn't give an ETA, but my understanding was that they intend to bring them back as soon as they can.
In the mean time, Mouser does still have a few hundred in stock of the 20% type, part #505-MKS2B041001C00MS, but that's the last of them from what I can find.
I checked Mouser and they have ~350 of the 20% left. I didn't check other suppliers.
But the good news is that they are *not* EOL.
