This Week on the Breadboard: OKKO Diablo v3
I had an Okko Diablo way back and quite liked it. I remember it being very good if a little polite. I tried building one when Robert first came out with a PCB but couldn't get it to work - probably the only pedal I have had not work from here.
I'd love to build a working one. Mr @szukalski if I ask nicely could I get some gerbers from you or should I build a Vero version? I have a DCA55 transistor meter which I didn't know could do JFETs. I just tried it but the battery is low - it says "Drain and Source not identified" and that's all it wants to say. But it will tell me which pin is the Gate. :)
Just so I'm clear, the final schematic also
*changes C5 to 470nf from 100nf
*changes body spdt on-off-on switch to c50k pot
*deletes r7, R8, and r25,
*adds c22 100nf after c13 10uf
*subs 1n5817s for the 1n4148 diodes at D2 and D3?
*Volume pot changes from b100k to a100k
*R19 is replaced with 50k trim pot
I have a j201 that measures 1.33 idss. Adequate?
Or would you still suggest the 2n5457? My through hole 5457 register 1.3-1.7, but my batch of SMD 5457 all register between 3.8 and 5.3. I don't know if that means I should worry about my measurements, but I'm guessing we're going for 1.3-1.7 and not 5.3.
The Final Schematic in post #19 is the Final Schematic. As much as I could, I kept the ref des from the PPCB Build Docs dated 3/20/24.
The Idss spec for J201 is 0.2mA to 1.0mA. Any part that measures outside that range is suspect.
SRPP circuits like this are very sensitive to Crs (gate-drain capacitance). One of the attractive features of J201 is the low Crs. Most other JFETs, 2N5457 included, have greater Crs and will cut off some of the treble. The issue with using JFETs with higher Idss is they will also have higher Vp, which affects the biasing. Best bet is to stick with J201 and arrange them so Q2 & Q4 have higher Idss than Q1 & Q3, respectively.
I just built one with the marvellous Mr Szukalski's PCB. It sounds much as I remember my old Diablo sounding, which is a good thing. Took me a while to dial it in. I seem to like Dynamics on full - the compression with it any lower is not my thing at all. So if I build it again I will probably just hardwire it on full.
I find it really interesting that I like to turn down Feed substantially to get the sound I want. I lose too much high end bite otherwise. It's a very Dumble/jazz fusion kind of sound otherwise. Nothing against that sound, just not what I am chasing. Mids I like in the middle setting - not with the switch in the middle, but the sound in the middle. I assume it's the 4n7 setting.
I wasn't sure hw to measure the JFET IDSS but found a simple circuit online to test for ths:
I used an IC socket to hold the transistors because I find they hold the transistors better than those DIP strip things. I only needed 3 pins for the transistor so used the two pins left over at the ends to make test points in the Vero board. Seems to have worked well - by making sure the IDSS was greater on the second JFET in each pair did the trick.
What could be the purpose of R5 and R15? They are on the wrong side of the cap-to-gate to be an SRPP (à la Catalinbread), and I do not see that they affect the amount of gain of the stages, or the gain-to-load ratio either. The only thing it seems to do on my sim is lift the signal 1.3 volts above ground for the negative cycle, instead of (almost) going against the rail... :unsure:
On another note, there's nothing preventing us from using a cheaper, higher-idss (like J112) for the upper fet, since it is not a true push-pull like the SRPP, am I correct? Aye, I'm a stingy bugger, but soldering smd J201 is a nuisance that I like to avoid as much as possible.
I think you mean R5 & R14. They do just what you say, they limit the voltage swing toward ground. This affects the symmetry of the clipping. That's the only reason I can think of for having those resistors in series with Q1 & Q3.
Let's look at one example, Q1 & Q2. Q2-S will be biased above Vref by Vgs which is dependent on Q2's Id, Vp & Idss. If you change Q2 to a different part #, such as J112, then Vgs will change which causes Vs to change which in turn affects the symmetry of the clipping. You could correct for that by changing Vref.
Another thing that's different between J201 and J112 is the capacitance between gate & drain, Cgd. Cdg of both Q1 & Q2, along with the output impedances of Q1 & Q2, create a low-pass filter. J112 has a much higher Cgd than J201, so the cut-off freq will be lower.
Both of those effects should be apparent in LTSpice.
Thanks Chuck, I'm finally wrapping my head around muamps. So much to tinker with here...
Ok, so all else in the circuit being equal, if I wanted to use J112 on Q4 and 2SK208R on Q3 (I like them a wee better than J201, more gate clipping and nice tone when source is directly tied to ground), this is where we would land. Frequency response almost identical, a tad less high end with the modification, but I prefer it:
I was under the impression that, the smaller the values on the voltage divider, the lesser the noise. Making it 10x does not increase noise, according to Spice... Interesting!
1Meg and 1uF do boost the gain and lower mids a little bit, but difference is minimal.
Onwards To The Breadboard!!! ⚡⚡⚡
I used to do detailed noise analysis as part of my job. Not a simple task and SPICE doesn't necessarily do a good job predicting noise. Opamp models rarely contain noise sources. Noise analysis has to take the entire circuit into account. We can't just look at one component in isolation and say "that's the dominant noise source" or "making resistors smaller will reduce the noise."
In this case, C46 bypasses the noise to ground, so the values of R47 & R58 don't really play a part in the overall noise calculation. Aluminum electrolytic caps can be quite noisy because they have fairly significant DC leakage and leakage itself is a source of noise. Does SPICE model that? No.
i'm having a hard time understanding how the 10k dynamics pot can get the voltage down to 5-6 volts. if i'm seeing it correctly, it forms a variable voltage divider with the existing VREF static voltage divider. but even turned to max resistance, it would be 10k on top and 20k on the bottom, which would only attenuate the voltage to 2/3, so 12V from 18V?
what am i missing?
