comradehoser
Have started implementing these changes, but I have some sharing issues with my Figment Preamp build around my limited stock of JFETs in specific ranges, so I'm going to have to test on both boards and make my picks. Luckily I socketed everything and have a handful of through-hole interfet J201s and NOS 2N5457s, but all of my interfet repro j201s are surprisingly consistent in the .38-.48 IDSS range, so I can't get as wide a spread of IDSS as indicated between the odd and even Qs if I stick with j201s.It's done. Here's the final schematic. The only changes from the schematic above are the Pres. Trim pot, voltages noted on the dwg, the notes and the revision #.
A few words about selecting Q1-Q4. The J201 Idss spec range is 0.2mA to 1.0mA. On my breadboard, Q1 & Q3 are in the middle of the range (0.54 and 0.60). Q2 and Q4 are at the top of the range (0.92 and 0.95). These are not magic numbers, but they work well for me. If you have an already built circuit, an easy check is to connect a DMM + lead to Vref and the - lead to Q2-S. Turn DYNAMICS all the way up. The reading should be a negative number, in the ballpark of -200mV. Now clip a jumper across R4. The voltage should still be negative. If it is, you're good. Do the same thing for Q4-S & R13.
Pres. Trim affects the range of the TONE knob and MIDS switch. Pres. Trim has the most influence when TONE is dimed.
All of these mods are easily kludged onto a Deofol board. If you don't do anything else, at least get the biasing right. Check the biasing on Q1-Q4. Delete R20. Move R18 from GND to Vref. Use a JFET with a higher Idss for Q5, like 2N5457.
I can say that putting the higher-IDSS 5457 (tried 1.3 and 2.0) in Q5 does definitely make it sound much more "open" for lack of a better word. Way more "overdrivey" and less "distortiony/fuzzy" especially at maxed gain and feed. I actually haven't decided what I prefer most yet, though. The presence trim I'll add. It looks very doable, even though I'll have a lot of floating stuff.
I lifted R18 and connected to VREF at the closest point (bottom of R6). I had hoped that between this and the changes around the odd and even Qs and the presumably higher headroom at Q5, the changes would mitigate the very odd ducking/swelling behavior of my pedal when dynamic is below 10:00 and gain/feed are maxed. But no.
Just curious--- what does deleting R20 do or don't do?
