rozencratz
I built the Mach 1 and tested it before putting it the enclosure and it sounded good. After putting it in, something happened and now the signal coming out of Pin2 on the Opamp is very quiet. I get the full volume at pin 3 so it's getting to the opamp ok but then the output of 2 is like 1/10th the volume. It also seems like maybe the A500K Drive pot isn't responding? I hear the signal appear to try and pull more gain but the tone doesn't change at all, if that makes any sense. I'm still very new to this so any guidance would be appreciated.
All voltage readings at the pins seem to be right, with 1,2,5,6 and 7 reading 4.8V and 3 reading 4.5V.
I've traced the signal through the rest of the board and everything else appears to be working properly. I replaced the opamp just in case and there was no change.
