Capsize Preamp / Broughton Fliptop
Erik S
5.00 star(s)
I bought my first bass about a year ago. I haven't played it a ton, but of course as soon as I got it I started making a list of bass related pedals to add to the build list. This one seemed to get some good reviews from the actual bass players, so onto the list it went.
When I first plugged it in it passed sound, but level was super low. I fiddled the trimmers for maximum volume, and then it was plenty loud and super dirty, but the tone was kinda bad. Did a quick search here and found a note from Robert - 5.87v on Q1 and 6.35v on Q2. Dialed that in and now it's less dirty, but whatever I like about the sound of my bass amp is still there and drive from the pedal sounds great. Not sure if it will get me to spend more time on the bass, but I like it.
I went down a little LED lens rabbit hole on this one. Some new lenses from Small Bear I hadn't tried before. More expensive than the Tayda ones, but they're a deeper red that looks fancier to me, and these ones are frosted inside which I think looks better than the "fresnel" style with the concentric circles.
Unfortunately I didn't measure them before I drilled all my enclosures. They don't fit in the 1/4" hole I usually drill for LEDs. In hindsight, they're probably 7mm, but I redrilled with a Letter J drill which was the closest I had without doing some digging.
That got the lens in the hole, but then I went to put the LED in, and it wouldn't snap in. My LED measured about .010" too big, so I turned it down in the lathe, but then it still wouldn't go in! Also too tall. I made it a flat top and jammed it in there, but I'm pretty sure these lenses just aren't meant to retain the LED like the ones I'm used to, and I should have skipped all that. :ROFLMAO:
Are you sure that lens is from us, Erik? I was looking to see if I could figure out why that gave you trouble, but I believe all of our LED lenses have that "grip" on the bottom of them to hold the LED in place. Sweet looking build in any case! I really like that finish.
Good catch! I've bought lenses from you in the past (my favorite ones) because you also have some that are that nice deep red - and those do indeed have the grip feature. I just assumed these were also from you because they were in a clear (not pink) bag.
After a little searching in my email, looks like these came from Stompbox Parts! I'll edit my post.
Sorry @StompBoxParts - I still love you.
Edit -
Holy Crap. I shouldn't be allowed to have a keyboard.
The lenses are from Small Bear. Final Answer.
Great build.
It is on my list to build during the Christmas break.
Bummer on the lens, really did the premium look of it!
Great build.
There's really nothing wrong with the lens. It just isn't what I'm used to. Once everything is soldered up and installed, the retention feature isn't important, and as a side benefit, it would be easier to take out of the box if I ever needed to.
And I still think it looks sweet.
I have a Brunken Blue enclosure from SBP I am using, with some decals in an Ampeg style font, that lens looks perfect for it!
