This may be a strange question… I am in the process of building a fuzz pedal (Twin Face) and am trying to bias the transistors.
First issue is that in the past I have grounded the black lead of my multi meter to the enclosure, on this build if I do that I get a reading of 0. The red lead is on the emitter of Q2. If I move the black lead to the ground tab of the input jack I get a reading. Why would this be? This is a powder coated enclosure from Tayda if that makes a difference… is this ok? Will I have terrible noise if the enclosure isn’t acting as a ground?
Second issue is that the voltage I get from the NPN side is negative and from the PNP side is positive. It seems it should be reversed from what I have read? I have built one other fuzz face and it was an NPN and my voltage at Q2 was negative as well… that pedal works well but is noisy. Am I reading wrong or is this backwards? How could I fix it if it’s an issue I need to address?
Last issue is that the best bias I can get on the NPN side is -3.6v. Would changing the 10k trimmer pot out for 20k give me enough travel to achieve proper bias voltage of (-)4.5v?The PNP side biased well, but I have that one on an external 10k rotary pot.
