Electric Druid Flangelicious issues
Davidow
Hello everyone, I recently assembled the Electric Druid Flangelicious kit I bought on Musikding. I'm having a problem I can't figure out: when I activate the pedal, the LED lights up, the sound comes through, but there's no effect whatsoever. I checked the voltages as described in the assembly instructions, and everything is fine, but even when I move the potentiometers, nothing happens; it's as if it's permanently bypassed. Does anyone have any advice? Thanks a lot.
Switch wiring seems fine to me, that was the first suspect.
An audio probe would be very useful here, do you have one or can you build one? It's very simple, just a few wires and a cap (100nF would be fine).
The schematic shows how the dry and wet signal both arrive at the output mixer, if the wet signal does not get to that phase it would explain how you would only get the dry signal. But that's just a first guess, and an audio probe would easily show you if it gets there at least.
