Kliche Buffer 1590a Builds
Vild
5.00 star(s)
I was able to barely fit this in a Tayda 1590a. I used the ppcb drill template to mark off some locations that seemed like they would work and that worked out for me. Lumberg small jacks are necessary obviously. The board is as far down in the 1590a as it can go and held in place by the led and bottom of the jack so it is a tight fit. I checked the middle lug on the switch after posting this and it was better than it looks at that angle but I went ahead and reflowed it anyway.
Also here's a shitty little perfboard version without a foot switch that I threw together for fun a while back! I could've done better if I planned out the layout better. Ashamed of that one tbh so I don't really need to be showing y'all that but it works correctly!
I built some buffers into a fast fret can and a small circular mint box, just for fun. No stomp switches.
